Brake Fluid Flush???
Old Feb 6, 2008 | 01:37 PM
Roperteacher's Avatar
I don't remember seeing it in the owners manual. When should we flush our brake fluid??? Thanks!
Old Feb 6, 2008 | 02:36 PM
Spooler's Avatar
Never read it in a manual but try to do it around 30,000 mile intervals.
Old Feb 6, 2008 | 02:42 PM
Thanks, anyone know which " Motive" brake flush unit to buy?? for an 07 5.9?
Old Feb 6, 2008 | 03:47 PM
DBLR's Avatar
IIRC we should flush the brake fluid every 2-3 years as it collect moister and it will degrade the brake fluid. I just take it in to a brake shop and pay them to flush it with my fluid that way I know what type of fluid is being used and I don't get dirty.
Old Feb 6, 2008 | 04:33 PM
Thanks guys, I put about 30,000 a year on a truck so I will probably do it once a year. Thanks for the advice.
Old Feb 6, 2008 | 04:55 PM
sabersix's Avatar
My Honda says every three years, no mileage limit. Due to the reason for flushing (absorbing moisture), I'd go by time not mileage in this case.
Old Feb 6, 2008 | 07:06 PM
coalburner400's Avatar
I do mine every 2 years, but the fluid will change color as it takes in moisture.
When the fluid turns a slightly darker color then its time to flush. After 2 years I notice an almost ale appearance. Don't let it get the color of a brown ale, that's a bit too long
Do a search on pressure bleeder - Its the way to go, and you can flush the entire system in 20 min.
DISCLAIMER = I have not performed a flush on the newer trucks. They might have more/less fluid, so the 20 min might not apply.
Old Feb 6, 2008 | 07:27 PM
Kurt Smith's Avatar
A few fluid mfg (I usually used Ate but there are others) make there fluids in 2 different colors so you know when the deed is done. Handy
Old Feb 7, 2008 | 09:34 AM
prattman's Avatar
I bought a K-D Tools bleeder similiar to this one for less than $80.00. I used a turkey baster to suck out all the old fluid from the master cylinder. Refilled with fresh brake fluid and kept bleeding until I had absolutley no air bubbles and fresh fluid at all 4 wheels. It works awesome. My truck is a '98 12 valve 4x4. The K-D tools bleeder I have seems to be discontinued. Here's a link to a Mity-Vac one: http://www.tooldiscounter.com/ItemDi...okup=MITMV6830
Like I said mine is very similiar. -Glen
Old Feb 7, 2008 | 06:42 PM
prattman's Avatar
I found the K-D Tool Brake Bleeder I have:
http://www.tooldiscounter.com/ItemDi...gle&kw=KDT3578
CACalomino
16
Mar 22, 2010 06:35 PM
Sam Turner2
Nov 18, 2008 10:17 AM
grantx5
Jan 5, 2008 06:56 AM
LFD2037
Nov 8, 2006 09:12 PM
tony
Jul 19, 2006 05:44 PM
