High Idle Equipment?
Old Dec 10, 2007 | 11:53 AM
  #31
DBLR's Avatar
I've noticed that on my 06 it will not idle up above 1100 Rpm's at first start up then once its warm it will do 1500 Rpm's.
Old Dec 10, 2007 | 03:51 PM
  #32
desertdieselboy's Avatar
Originally Posted by dodgezilla04
for the manual trans trucks, you'll need a ecm pin that comes with a 6" pigtail. you gotta ground pin 22 on the ecm harness, ground it directly to the ecm mounting bolts. pin from cummins was $7.
then have it enabled, or buy a programmer that does it.
mine works great. took 10 minutes to install the pin.
at least this is how the nv5600 folks do it.
I have an `04.5 w/ 5600. So, this is ALL that I would have to do to add the high idle option to my junk? Is there a detailed write-up on this? I`d be willing to do it if it hasn`t been done.
Thanks DTR, your a wealth of knowledge!
Old Dec 11, 2007 | 10:56 AM
  #33
Hayseed's Avatar
Thumbs down
Originally Posted by mastercaster
you don't need any extra parts to enable the high idle on a manual trans!! i did mine and have posted how to do it before (on other forums). you need to have the dealer enable it, just like on the auto trans. the only other step is to ground the one wire. the wire is located on the firewall. driver side, far left bottom firewall. basically if you go staight back from the emergency brake handle to the firewall, you'll see a large wire harness, white in color. you can unhook that harness, and behind it there is a very short (4 inches maybe) dark green wire coming through the firewall. the wire has a heatshrink cap on the end. strip the end of the wire and ground it to one of the two bolts next to the harness. that's it! let me know if you need more info. you'll need your flashlight to see that little wire back there. that's it folks no money on any parts. that wire is for the optional clutch safety switch. it is really not needed, as the transmission has to be in neutral and the emergency brake set, in order for the high idle to activate. if you touch the brake pedal, release the emergency brake or put it in gear, the high idle will disengage.
will this procedure work on an 07 6.7?????
Old Dec 11, 2007 | 02:47 PM
  #34
mastercaster's Avatar
yes, it will work for model year 07 and up 6.7L. that is what i have.
Old Dec 26, 2007 | 05:35 PM
  #35
eobigbull's Avatar
mastercaster
Hey i just did as you disribed and it worked perfectly.Thank you for the instructions. LP
Old Dec 26, 2007 | 07:49 PM
  #36
no problem.. that is what these forums are for. gotta love 'em!
Old Dec 26, 2007 | 08:53 PM
  #37
SpinEmNSmokeEm's Avatar
I did the same thing this weekend and it works great!! I did notice that the wire is green w/ a pink stipe in case anybody wonders when they get back in to it.
Old Dec 27, 2007 | 08:56 AM
  #38
Hayseed's Avatar
Mastercaster, does the truck know if it is in gear or is it just when you shove the clutch down it disengages?? You sparked a thought about a remote starter!!
Old Dec 27, 2007 | 11:01 AM
  #39
the truck doesn't really know if it's in gear per say, but as you know, to start the truck, you have to have the clutch depressed. there is a switch that detects that. there are a couple of companies that make quality remote start units for manuals, but i can't think of the names off hand. i'll get them for you though.
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
