What temp causes 3 cylinder idle to turn on during high idle?
Old Jan 17, 2005 | 06:08 PM
dieselnewbie's Avatar
Question What temp causes 3 cylinder idle to turn on during high idle?
It's going down to 0 tonight and I want to see if it kicks in during the morning high idle warmup.
Thanks!
DT.
Old Jan 17, 2005 | 07:37 PM
Gypsyman's Avatar
3rd gens don't have the 3 cyl idle, just high idle of 1000 rpm.
Richard
Old Jan 17, 2005 | 08:48 PM
phox_mulder's Avatar
Richard
I thought they still did if it got cold enough.
If it's the same parameters as the 2nd gens,
1. Intake Manifold Temperature less than 0°C (32°F) and,
2. Coolant Temp is less than 60°C (140°F),
you get the high idle.
Additionally, if Intake Manifold Temperature (IMT) is less than -9°C (15°F), and all of the parameters above are met, three of the cylinders will be shut off upon reaching 1200 rpm,
Just might be cold enough there, if it's been enabled.
phox
Old Jan 17, 2005 | 11:55 PM
roan65's Avatar
I've had mine down to -50, and I've never had 3 cyl shutdown,
Old Jan 18, 2005 | 04:26 AM
JohnnyH's Avatar
I dont understand the purpose. It seems like it would warm up better if all 6 were firing.
Old Jan 18, 2005 | 07:58 AM
Welp, just started the truck after 9 hours in the freezing cold (not like north of the border but cold).
It's now 0*F and no 3 cylinder idle.
The auto high-idle kicked on immediately but still no 3 cylinder idle.
Oh well.
Old Jan 18, 2005 | 06:29 PM
bkrukow's Avatar
I thought they where suposed to run on 3 cyl as well below a certain temp but it has not done it for me either. Its been well below 0* F a few times and just instantly goes to 1000rpm on all cylinders. Must not be on the 3rd gen trucks.
Old Jan 18, 2005 | 08:15 PM
gsbrockman's Avatar
To my knowledge, the rationale was that 3 "dead" cylinders made the 3 "working" cylinders work harder, therefore a shorter warm-up time. Our 3rd GEN trucks have no 3 cylinder mode, unless you're unlucky enough to have failing injectors.
Greg
Old Jan 18, 2005 | 10:48 PM
Blygy's Avatar
Had a DC mechy type guy tell me that the 3 cylinder warm was the greatest thing.. Told him to enable it on my truck as I wasn't aware it was available on the 03s and up. Guess what, it isn't we couldn't find it in the computer.
Blygy
alramr
87
Jan 31, 2010 06:21 PM
Ram1999
Feb 11, 2007 10:49 AM
Katmandu
Nov 9, 2006 12:01 AM
Baja
May 7, 2006 05:11 AM
J.DAVY
14
Nov 9, 2005 09:25 AM
