fuel filter differences
Old Jun 10, 2010 | 11:54 AM
1mathom1's Avatar
Search is behaving badly...errors out then won't let me run it again....blah blah.
My question has probably been answered before.
How can you tell from the outside if the filter is the filter/shell combined unit or if it has been swapped for the type that you can replace only the filter.
2008 mega 6.7
Old Jun 10, 2010 | 01:38 PM
Blake Clark's Avatar
The stock 08 style filter unscrewed from the bottom, the top of the filter setup is rigid.
The new style '10 and up is a drop in type like the 5.9's
Old Jun 10, 2010 | 02:37 PM
Lil Dog's Avatar
From the outside, the only difference would be the serial number on the shell/filter.
The original filter was
And now the upgraded shell filter is:
MOPAR 68061633
And the main difference is the filtration level with the new filter/shell combo for 5 micron.
Old Jun 10, 2010 | 02:39 PM
Whoops
Misunderstood.....
Thought you meant the difference from the cansiter style to the newer 4th gen style.
My bad
Old Jun 10, 2010 | 03:23 PM
got_soot's Avatar
Soot For Brains!
for some reason i dont like the drop in filters like the 5.9's. I wish they was like our mack semi.. about three filters in a row and they are screw on's. oops forgot about the one beside the injection pump too.
Old Jun 10, 2010 | 07:05 PM
archer's Avatar
Get your fuel filter from Cummins or Freightliner it is a FS-43257 that is the one that you replace the cartridge, should be $35 to $40, less than mopar i think. Loosen off the filter then open the drain, takes a couple of min to drain, other wise you will be covered in diesel. I own a mobile oil change service for heavy trucks and found out the hard way.
Old Jun 10, 2010 | 11:21 PM
Scotty's Avatar
Top's Younger Twin
Whoops
Misunderstood.....
My bad
Me too
Old Jun 10, 2010 | 11:28 PM
rfeiller's Avatar
the canister style is different the inside of the old style has ribs the canister for the newer "filter in a filter" is smooth to allow for the larger element. you can't install the new elements into the older canisters.
Old Jun 11, 2010 | 01:15 PM
Lil Dog's Avatar
Good point. The old canister is fluted inside and won't hold the new elements.
Old Jun 16, 2010 | 11:50 AM
1mathom1's Avatar
Had the truck at the dealership for the ECM service notification and asked what a shell/filter set up would cost. $80. "Hello, Geno? I need to order...."
Old Jun 16, 2010 | 01:56 PM
archer's Avatar
Ya just what i thought, Fleetguard FS-43257, get at Cummins or Freightliner, it is a Cummins filter, should be about half that price.
Old Jun 16, 2010 | 11:28 PM
Lil Dog's Avatar
Thanks for the FS number archer!
Old Jun 30, 2010 | 06:03 AM
sabercat's Avatar
is that just the shell, or shell and filter? after buying it, just have to replace the filter? thanks
Old Jun 30, 2010 | 05:12 PM
archer's Avatar
That is both, and yes just replace the filter next time.
nvrenuf
Apr 24, 2008 03:12 PM
mitch@jc'sCTD
Jan 11, 2005 10:17 PM
BlowBy
43
Oct 29, 2004 04:58 PM
Rolngthun
Sep 30, 2003 05:50 PM
May 11, 2003 12:40 PM
