Fuel Filter Differences?
Old Apr 23, 2008 | 12:40 PM
nvrenuf's Avatar
Fuel Filter Differences? (2006)
I'm trying to change my fuel filter for the first time and I've run into problems. Filters from both the Dodge and Cummins dealers are slightly different than my original. My original has a hole on both top and bottom whereas the replacements only have holes on the bottom. The top hole on mine puzzle pieces into a male "bump" on the filter housing lid. Since the bump can't fit into the filter I can't seem to compress the lid far enough to start the threads, I'm afraid to force it.
Is this a common problem or just me?
Old Apr 23, 2008 | 12:54 PM
Roperteacher's Avatar
The Fleeguard 7 micron filters and the Baldwin PF 7977 are the same as the factory one that came out of my 5.9l. Are you sure they gave you the correct filter?
Old Apr 23, 2008 | 12:55 PM
Wait, You shold ONLY have a hole in the Bobbom of the filter. My facotry one and the ones I listed above neither have holes at both ends. Sounds like you have the CORRECT one now!!
Old Apr 23, 2008 | 01:03 PM
nvrenuf's Avatar
I'll agree it sounds like the replacements are correct but they wont easily fit. LikeI said, the lid has a bump that fits into the hole on my OE filter. Without the hole the lid needs about 2 more rings of thread to reach the housing.
Old Apr 23, 2008 | 07:43 PM
NickBeek's Avatar
That bump on the lid is most likely so you can't use the old 10 micron filter.
Old Apr 23, 2008 | 10:07 PM
nvrenuf's Avatar
So noone has had to deal with any physical differences in filters? I can't believe that I have the sole truck with an odd OE filter.
Old Apr 23, 2008 | 11:13 PM
I have had an 04,06, now 07 5.9 and I have NEVER seen the bump on the lid! LOL COuld you take a picture and post it here!!!
Old Apr 23, 2008 | 11:19 PM
larryt's Avatar
Others have had this problem. Some of the newer Fleetguard filters have
a slightly larger upper brim. Usually about 1/32" larger on the newer filters.
I use the Geno's metal filter cap and I found I had to sand/file about 1/32"
off the brim before I could seat the filter far enough into the cap. If you have
a 6" dial caliper you can compare the new and the old filter brims.
larry
Old Apr 23, 2008 | 11:26 PM
TonyB's Avatar
Other than a stamped PN on the filter, there are no visible differences between the 7u and 10u filters.
I think you have the wrong filter. The part that mates tot he filter lid should be flat (no hole) and the end that goes into the filter can has a hole to fit over the center post. Look at this one: It's sitting on the flat and showing the hole for the center; basically, it's upside down.
HTH
Tony
Old Apr 24, 2008 | 11:24 AM
DBLR's Avatar
I've found it easier to snap the cap on to the new filter and then put in to the filter housing and tighten it up. If I put the filter in to the housing first and then try to put the cap I can't tighten it up unless you force the cap down on to the filter.
Old Apr 24, 2008 | 12:48 PM
Power Ram 4X4's Avatar
i had customer with the same problem and it was part of the old filter still stuck in the cap. the cap should be flat.
Old Apr 24, 2008 | 03:12 PM
nvrenuf's Avatar
Bless you kind sir!!! I'll check that tonight. THANKS!!!
1mathom1
13
Jun 30, 2010 05:12 PM
mitch@jc'sCTD
Jan 11, 2005 10:17 PM
BlowBy
43
Oct 29, 2004 04:58 PM
Rolngthun
Sep 30, 2003 05:50 PM
May 11, 2003 12:40 PM
