Sponsored by:
Sponsored by: CARiD
differences between diesel fuel tanks & others?
Old May 8, 2003 | 02:58 PM
butchera's Avatar
Re:differences between diesel fuel tanks & others?
If your talking aux tanks, the big differance between the diesel and gas tank is that the gas tank has a high pressure fuel pump with it. The diesel tanks don't have/need the pump.<br><br>
Old May 8, 2003 | 09:59 PM
rich's Avatar
i believe the tanks are made the same except for the fuel feeding system once the fuel is out of the tank
Old May 8, 2003 | 10:37 PM
Mexstan's Avatar
Pavonis, you have got me curious. Are you sure that the tanks are made from 5150? Could it be 6061 instead?
Old May 8, 2003 | 11:28 PM
Duelin's Avatar
What about the marine &quot;Plastic&quot; tanks ? I have used these twice now to replace a rusted leaking steel tank, and a corroded aluminum tank . They are used comonly in boats and are available fairly inexpensively in a wide vaiety of shapes and volumes. I don't remember the type of plastic but am sure that if it is safe for gasoline , it would be safe for our diesels.<br>gary
Old May 9, 2003 | 10:59 PM
Nevada's Avatar
[quote author=Duelin link=board=8;threadid=14502;start=0#136419 date=1052454488]What about the marine &quot;Plastic&quot; tanks ? I don't remember the type of plastic...[/quote]
High Density Polyethylene
Old May 10, 2003 | 02:30 AM
TxDieselKid's Avatar
anybody ever seen a sump for our trucks to have a gravity fed tank?
Old May 11, 2003 | 12:40 PM
I just did the fuel system on my truck, and used this new sump that is a bolt on. We got the idea from a friend, and they are being made up right now. Mine was the first one out of the factory. I don't have any pics(get them on Monday), but here is the CAD drawing of it.<br><br>Pic of sump<br><br>So far I'm loving it. Has a -10AN ling comming out of it, and all the way to the prefilter, and into the PE4200. After pulling the tank, and seeing the crud in there, there is no way I would EVER run a pump without a prefilter. The -8AN line goes all the way into the stock filter housing, does NOT shrink down to -6AN line most. Had to drill out the filter housing for this, but it came out nice. <br><br>This is over kill for most, but I like it so far. <br><br>Andrew
rwhite1
Oct 27, 2011 08:06 AM
ocsurf16
Sep 25, 2006 10:36 AM
rico334
20
Jan 19, 2006 04:28 PM
Trebor
Mar 24, 2005 07:15 PM
CAPTNDAVIE
Nov 25, 2004 10:50 AM
