EGT temperature
Old Jul 31, 2009 | 09:49 AM
ralphpam's Avatar
EGT temperature
I had a egt probe installed pre turbo on a 2009 Dodge 3500 ctd. We tow a fifth wheel trailer behind it and would like to know at what temperature I should get concerned as I can find no information in the manuels?
Old Jul 31, 2009 | 10:02 AM
Blake Clark's Avatar
1350 is the upper limit you want to see at any time.
With my edge on 2 (tow setting) 36ft gooseneck and 125hp kubota i only saw hig 1000's low 1100's.
Old Jul 31, 2009 | 03:50 PM
Lil Dog's Avatar
Depending on load and the DPF cleaning routine, you will see as high as 1400°F. Under load however it will be less. Now you will know when its going into DPF Regen as you will be towing along at about 8-900°F and then it will take off to 1400°F for up to 20 minutes.
Old Aug 1, 2009 | 09:16 AM
Your right, forgot to take the emmisions equipment into consideration.
The numbers I stated are on the Chrysler UnApproved High Flow System.
Old Aug 1, 2009 | 01:37 PM
Lil Dog's Avatar
Heheh.. I am not in that league yet.. Will be soon however.
Old Aug 1, 2009 | 08:43 PM
gsbrockman's Avatar
Must be a MegaCab thang......mine fell off as well; I also see about the same EGT's , too.
Greg
Old Aug 4, 2009 | 05:29 PM
Hetdiesel's Avatar
wont the temp be different depending on if he has the probe mounted pre or post turbo.
Old Aug 12, 2009 | 02:25 AM
Dinner's Avatar
That is correct. If it is post turbo instead or pre, the gauge will read lower temps.
Old Aug 12, 2009 | 10:09 AM
Chubby's Avatar
Yes those readings are correct. But Mine now after the delete are 700-750 70 mph no load before i didnt see much below 900
ralphpam
Aug 18, 2009 03:57 AM
jmccart
Mar 18, 2007 10:03 PM
mikewats
Feb 16, 2007 09:55 AM
jmccart
14
Nov 20, 2006 06:45 PM
