what do you think
what do you think
i was driving back from about a thousand mile trip this weekend, and towards the end, my truck started mis firing a couple times every thirty miles or so. i was told by a diesel tech shop today that it might be injectors. it seems to me that an injector would be a constant problem though. any ideas
iput it back on stock yesterday cause i was wondering about that. its still doin it though. i ran some lucas injector cleaner in it a couple weeks ago. didnt really make a difference. is that diessel clean in a grey bottle
My injector showed it bad side at idle and was unnoticeable at higher RPM, but it did get worse - higher and higher eng. speed before disapering. What you are discribing sounds more like sucking some water through - fuel supply related. How much water are you getting throug the filter. If your arre iding smoth I would not think injector right off?
Are you seeing signs of watter from filter. Do a drain on your filter and catch in clear glass or plastic and see howmuch water you are getting. If you see some water I would change filter and drive see if prolem continues.
If not I would drive and see what happens and check water agine.
cyawallac
Nov 1, 2011 11:37 PM
Totallyrad
Nov 29, 2010 02:34 AM
rossco
Aug 23, 2007 06:17 PM
