I Think ? See What You Think. A/C Issue
Old Oct 30, 2011 | 11:43 AM
cyawallac's Avatar
I thinks it's the blend door actuator down by the hump on the passenger side. When I turn on the A/C it seems to be turning continuously round and round, would this be my issue or should it stop at some point. I've got a 2002, A/C blows ice cold then outside warm for approx. 5 seconds, long enough for me to hear a door pop either open or close. The A/C will blow cold for about 1 minute, then blow what feels to be outside warm for about 5 seconds. It dosen't matter if I'm driving 75 mph or setting still at idle, everytime it happens I can hear what seems to be a door pop. Compressor is working, big line is cold and dryer is cold. I'm no A/C man and I don't want to have to give up my first born to a shop to fix, if you know what I mean. Any ideas or thoughts would be appriciated.
Old Oct 30, 2011 | 12:52 PM
torquefan's Avatar
If you can physically see the linkage turning around, it sure sounds like the problem. Either something has broken in the actuator, or the door is broken inside the HVAC housing. The next step would be removing the actuator to inspect it, and work the door manually with your hand, to see if it works smoothly, with a defined stop at each end of its travel.
Old Oct 30, 2011 | 01:03 PM
RCW's Avatar
RCW
Do a search on the actuator door, that is a common problem and not too difficult to fix.
Old Nov 1, 2011 | 11:37 PM
Tejas TJ's Avatar
On my truck when I was replacing the evap core and heater core this past weekend, the black plastic piece on the bottom of the blend door cracked into a couple of pieces. It's some what rectangular and it's where mounts into the actuator. I glued it togather the best I could I hope it's holding up, can't tell if it's working or not.
Shorts
Jun 29, 2013 09:23 PM
Polaraco
Jun 1, 2011 12:16 AM
tmleadr03
Dec 24, 2007 10:01 PM
bigfish5
Mar 20, 2007 09:08 PM
cowboy717
Oct 13, 2006 06:22 PM
