using winter anti gel
Old Dec 15, 2003 | 09:47 AM
Mallard's Avatar
I usually use Amoco Diesel and it is advertised as "winterized". Do I still need to add my own anti - gel treatment to my fuel ? If so, what is the recommended anti - gel product to use ?
Old Dec 15, 2003 | 09:53 AM
Commatoze's Avatar
Re:using winter anti gel
Where 'yat, Mallard?
Old Dec 15, 2003 | 10:10 AM
Mallard's Avatar
I'm from South-Central Wisconsin in Horicon (about 1 hour North of Madison), and I travel to Northern WI to go ATV and Snowmobiling with my truck quite often.
Is there a certain outside temperature range that we need to worry about gel happening or not happening ? I'm a rookie at owning a diesel. In browsing the net I saw diesel additives for normal driving as well by PRI. Any input is appreciated.
Thanks.
Old Dec 15, 2003 | 10:30 AM
Commatoze's Avatar
Yeah, I'd carry some anti-gel for those really cold days. Most, if not all fuel suppliers will blend the diesel oil in the winter months. I dose mine every fill-up with Stanadyne Performance which also lowers the pour point some more. Can't hurt. You can always tell when the blend is happening because your mileage will drop somewhat.
Old Dec 15, 2003 | 05:55 PM
Lightman's Avatar
Mallard- additives are cheap insurance, and its nice to know you're not going to gel up. I'd only really worry below 0F.
Since you're in WI, you are lucky enough to have access to Amoco Premier in your state. Its a true premium diesel, low aromatics and 50 cetane minimum. Only a few states get it, but it's worth whatever they charge. There's a map of the locations somewhere floating around the web, if I see it I'll post it for you.
Old Dec 15, 2003 | 10:22 PM
AK RAM's Avatar
I like the idea of added insurance as well when the temps are in the single digits or -0. I have tried them all (that I could find up here), Stanadyne, Power Service, Shell. I have never had a gelling problem with any of them, but even with that nasty winterized fuel, the truck is very quiet when I use the Shell Rotella DFA...no clatter at all. Sounds like crap in the winter when I use Power Service. Stanadyne is OK, however it is much more popular amongst the forum users. Just my observations. As far as gelling goes, they all did the job, even in minus temperatures.
Old Dec 15, 2003 | 10:25 PM
Lightman's Avatar
WHen I lived up north, in single digit F temps, the stanadyne made a noticeable improvement in starting, clatter, and idling. THe powerservice did nothing. It did nothing because powerservice is 77+% diesel fuel and is really pretty worthless IMO.
Old Dec 16, 2003 | 08:13 AM
Mallard's Avatar
Thanks for the great info. I am going to order me some stynadane right away. I saw that it come in a pre-pack "one-shot" and in bulk quantities. What are most of you guys using ? The one shot is rated for 30 gallons. I typically need about 22 or 25 gallons when I fill up. Will the extra overdose hurt anything or should I use bulk and funnel what I need in ?
Old Dec 16, 2003 | 08:43 AM
Lightman's Avatar
It won't hurt anything to use extra, but it's cheaper to buy in bulk. I think most get the pints that treat 60 gals with the little level indicators on the side. That makes it a LOT easier to tell how much you're pouring in, without funnels or measuring cups.
I believe it's cheapest here - http://www.dieselpage.com/add1.htm
Old Dec 16, 2003 | 08:58 AM
Commatoze's Avatar
Mallard, as a reference, I purchased a 5 gallon can of Stanadyne Performance Formula for $116.00 (tax included). The same amount in One Shots were $180.00. I bought 2 of the One Shots because the bottles fit great in the side pocket of the door. Try to get it local because shipping really adds to the price. The 5 gallon can really isn't a problem. I pour from the can into an old 96 ounce Power Service jug, then fill the One Shots from that. There's a nifty measuring cup available with a hose attached and a trigger mechanism to empty the cup. I haven't found it local though.
Old Dec 16, 2003 | 09:12 AM
Lightman's Avatar
The problem with that is, the one shot forumula is about half the concentration of the formula in the other bottles
Old Dec 16, 2003 | 09:17 AM
GrandpasRam's Avatar
John Deere winter formula is also a very good additive; if you have a John Deere place nearby, you can get it in gallon jugs, or 16 oz. plastic bottles, or 5 gallon cans.
Old Dec 16, 2003 | 12:23 PM
stevenknapp's Avatar
FYI, Nalgene is a great material to haul around nasty stuff. I keep some spare oil for my bike in a 1/2qt bottle, it never leaks, the nalgene holds up great. It's designed for stuff like this.
Plus they are cheap if you buy them from lab surplus shops, for example .35/per 8oz bottle from American Science and Surplus:
http://www.sciplus.com/singleItem.cf...LogFrom=Search
What about Howes diesel anti-gel? I've noticed it at truck stops in big displays.
Old Dec 16, 2003 | 02:35 PM
1sttruck's Avatar
I bought a case of 1 pint bottles of Stanadyne at a local diesel repair shop for something like $60. I usually fill up when the gauge hits 1/4 tank and typically put in a bit over 20 gallons, so I pour in 1/3 bottle before fueling. I keep 1/2 liter bottles of water in six pack packaging for beer in all of the vehicles anyway, so I just replaced one of the water bottles with the Stanadyne.
Old Dec 17, 2003 | 06:31 AM
Mallard's Avatar
Thanks everyone for the great info. I have my pints of stanadyne and am ready for the cold winter weather.
stratofisher
Aug 25, 2007 06:15 PM
ajg617
Feb 16, 2007 09:29 AM
jj3500
Feb 11, 2007 12:44 PM
BA05'CTD
16
Oct 27, 2005 02:58 PM
shaft
15
Nov 19, 2003 08:33 PM
