Uh Oh G56 fluid change reveals metal!!!
So I changed my transmission fluid and transfer case fluid today. I ended up going back with OE Mopar ATF+4. I found it at Wally World for $4.42 / quart. Any way when I dumped the trans the plug has a little magnet in it. The little magnet had shavings and sludge stuck to it. The magnet is about 1/4 inch in diameter and with all the stuff stuck to it, it was about 7/16 inch in diameter. The fluid was a little dark but not too bad. Don't ask how it smelled, cause my nose doesn't work, I can't smell a thing. Any one here ever change their G56 fluid out? What did you find on the plug?
BTW, the Mopar ATF+4 said it was a full synthetic fluid. I didn't know that.
I have always seen metal when changing the oil in trannys. It's just part of the deal. It might become less with each change, but don't count on it. The hardened gear teeth have a very small contact area and there is a Cummins pounding away on them. Man, that oil has a job!
It's amazing that all that hard facing can wear off the teeth and they can still be fine. The poor bearings are just bathed in that stuff.
It would not hurt to change the oil more often. Reminds me of my KTM, I changed the oil every day for a while. It was dirty in that short of time. Finally it started coming out cleaner so I kept extending the change interval.
John
John
I changed my G56 to Amsoil ATF. I get a little sludge on the magnet but nothing a little rag doesn't clean right up. I agree on the changing of it sooner. I change mine every 20,000 or so.. GOod insurance I guess since I tow heavy and lets me look at things before they get out of hand..
When I did the NV5600 on my last truck there was a fair amount of metal muck on the magnet in the bottom of the case.
I just did my G56 and it also had some fine muck on the magnet.
As long as there aren't chunks of bearing or anything, and the transmission sounds OK and shifts fine, I'd say no worries...
mattmanj2001
Aug 19, 2010 08:18 PM
gnuesse
Apr 16, 2007 07:10 AM
