G56 Fluid change question
Old Apr 14, 2007 | 08:04 PM
gnuesse's Avatar
Its about time for me to change the fluid on my 06 with the G56 6 speed trans. I was going to use Valvoline ATF +4. Is there a better fluid to use out there? Whats the best way to get the fluid in after it has been drained? The fill plug is close to the exhuast and there is not much room at all for pouring fluid back in. I just did my transfer case today and used valvoline atf+4.
Old Apr 15, 2007 | 05:37 AM
mladrow's Avatar
I have an 07- I just changed the fluid to Valvoline +4 the other day. I got one of the screw on adapter with vinyl tubing attached- turn the bottle sideways and it'll slip up between the tranny and the "hump"- squeeze the bottle and fill away. BTW- they changed the plug size from the 5600 if you're used to those- used to be a 17mm wrench and now a 14mm. The only caution I could add is I'm not thrilled with the shift quality after the change- not bad, but seems a little harder to shift when cold- I expected just the opposite.
Mark
Old Apr 15, 2007 | 09:16 AM
Jfaulkner's Avatar
Muted User
In my '05 I just removed the console and shift tower and poured it in the top.
Old Apr 15, 2007 | 07:37 PM
wmonroe's Avatar
I am going to be doing mine in a few thousand more miles and am also curious what everyone is using.
Will
Old Apr 15, 2007 | 09:44 PM
coal913's Avatar
I use the royal purple synchro max and it made a difference in the shifting
Old Apr 15, 2007 | 09:54 PM
RobG's Avatar
How many quarts does the G56 take?
Rob
Old Apr 16, 2007 | 07:10 AM
mladrow's Avatar
6 quarts is the spec
Scraper4x4
Dec 26, 2008 09:34 AM
NickBeek
13
Jul 29, 2008 09:16 PM
CalypsoCowboy
24
May 18, 2008 09:04 PM
SundayMoney
Feb 20, 2008 12:20 PM
gnuesse
Mar 18, 2006 04:44 PM
