Stupid coolant hose........
Old Nov 15, 2013 | 03:29 PM
anpconnors's Avatar
Any aftermarket options, Heater Plumbing 5.9L Diesel
My truck is leaking at the highlighted area. Anyone find an aftermarket hi temp hose? I have the constant tension clamps.
Old Nov 15, 2013 | 03:45 PM
Grit Dog's Avatar
My 07 doesnt leak, knock on wood. Is this just an 06 issue?
Thinking ahead if I should replace this hose now for a while, but especially this winter looking at -20 deg temps and wife's primary vehicle while I'm out of town.
Old Nov 18, 2013 | 02:30 PM
Scottygl62's Avatar
Originally Posted by DieselDo
Yea my 06 leaked too.thats a major problem with these 06 Dodges,ranks right up there with the melting glow plugs,engine destroyer Dmax, don't you think. yea us Dodge Boy's got it bad.
Ditto for 07. Changed mine Saturday. Major pain and I had the exhaust downpipe and collar from Turbo off as well. Still don't want to do this job again. Maybe trade truck next time it needs changing. Of course I'm 68 and these things get harder to do as we age.
Old Nov 18, 2013 | 08:52 PM
Country23047's Avatar
they do that.....
Old Nov 19, 2013 | 01:38 PM
ColinP's Avatar
my '06 leaked right there too before i tightened it up
Old Nov 20, 2013 | 05:48 PM
BacktoBasics's Avatar
Originally Posted by fatpete
Do a search on the forum for the exact part numbers in other posts that deal w this problem- but here's the deal: there is a dodge replacement kit for this part, comes packaged with better hose and two constant tension hose clamps. The screw type hose clamps can't adjust to the heating/cooling this time of year w the temperature changes, that's why they leak. The better hose and constant tension clamps fix it. It takes about 2 hrs to swap out and it's more work than it appears. It's definitely doable yourself though.
X2 the updated hose and constant tension clamps fixed mine... my dealer kept using the hose wrapped in the foil and couldnt wouldnt source the new kit which was a silicon hose so I ordered it offline and
Old Nov 21, 2013 | 11:59 AM
JRD's Avatar
JRD
Just changed mine in about 30 minutes. I got a different looking hose from the dealer with the same part number. He told me they changed it up due to constant leaking issues. Mine was orange with no heat shield, unlike the one I took off that had the heat shield. I pulled the 13mm bolt that holds the rear hard line to the block and moved it out of the way. Made things MUCH easier.
Jim Lane
Mar 23, 2013 09:31 PM
bigredbrick
Jul 13, 2008 04:12 PM
usmc2311
Nov 17, 2007 09:27 PM
Hoss
May 19, 2005 02:28 PM
JKM
Mar 22, 2005 06:29 AM
