Small spot of fluid found under truck... Drive 5hr today?
Old Apr 11, 2007 | 10:53 AM
subspd's Avatar
Exclamation Small spot of fluid found under truck... Drive 5hr today?
I am in a really tough spot I came out and found a 12" dia spot under the truck there was a very slight drip that has now stopped coming from above the bell housing. I went and drove it again and now there is nothing. My fluid levels all check out. But my coolant level is only a 1/4 about the fill line. Is this normal? It looks like murky water... (the drip)
I ask all this because I am 2 hr from the closest dealer and I have a 10hr run that I have to make in the morning???
Would you drive it? I don't think I have a choice I could make a run to the dealer but if they can't fix it today I am scr*wed!
Can you get this coolant at a local parts store or is it hard to come by?
Is it even the coolant?
Old Apr 11, 2007 | 11:06 AM
djbikeman's Avatar
There is a heater hose on the exhaust side of the block that is notorious for being loose and leaking on the 2006's. If you get under the truck and look up the short hose runs horizontally under the 4 or 5 cylinders I think. You can see the two hose clamps. You should also be able to see a white/pink stream where the coolant came down the block if that is the problem. If so, just tighten those clamps and it will be gone.
Old Apr 11, 2007 | 11:30 AM
subspd's Avatar
DJ,
You are the MAN! It was right where you said it would be, now how did you know that? I tightened both clamps on the rubber hose section where it runs between the hard pipe. I have the truck idling right now to see if it stops.
Now to just find some fluid...
Thanks so much again!!!
Old Apr 11, 2007 | 02:02 PM
subspd's Avatar
Can I use regular filtered water or should it be distilled?
Old Apr 11, 2007 | 02:49 PM
surfram's Avatar
Get the premixed (50/50) coolant/distilled water and top it off. Prestone has the orange/red cap and meets mopar specs.
Old Apr 11, 2007 | 02:55 PM
subspd's Avatar
I already picked up the mopar coolant earlier. Is it premixed? I think the bottle said to add water.
Old Apr 11, 2007 | 04:51 PM
djbikeman's Avatar
Been there...Done that.
I had that same exact thing happen on my 06 and have read a few posts about others having the problem for the last year or so. Good to hear that your problem was a simple fix!
Old Apr 11, 2007 | 06:06 PM
truckjunkie's Avatar
Are the '06's required to have HOAT antifreeze? I didn't know Prestone had a premix that met the specs. Learn somethin' new every day.
BTW - there's a couple of threads about coolant and distilled water on this site being discussed right now. Here's the links:
https://www.dieseltruckresource.com/...d.php?t=145234
and
https://www.dieseltruckresource.com/...d.php?t=145082
Old Apr 11, 2007 | 08:04 PM
icrider's Avatar
right on...that is why I forum rocks. nice work
Old Apr 11, 2007 | 09:28 PM
subspd's Avatar
Thanks again for the help guys! This forum rocks because of people like you all.
Old Apr 12, 2007 | 03:04 AM
socal 610's Avatar
Been there done that last year .This forum saved me a trip to the dealer
Old Apr 15, 2007 | 09:44 PM
slickr1's Avatar
leak
Hey that is a pic of my leak also. Discovered a orange spot on the garage floor ater a week of the truck being parked ( 06 mega CTD) Put about 2 twists on the screw clamps and so far so good. Hope there is no more leak in the am. I am making a 12 hr run to Missouri for 2 weeks of turkey hunting. Truck has 12k on it.
Old Apr 16, 2007 | 10:08 AM
subspd's Avatar
Did the same and have not had the leak since...
Old Apr 18, 2007 | 10:17 AM
countryroad's Avatar
Thanks for the pics. Mine was leaking too!! Easy fix!!!
SOhappy
Jul 17, 2013 04:03 AM
CruisingRam
Jan 19, 2012 04:45 PM
kwast
Dec 11, 2007 06:43 PM
sadlerb_98
13
Aug 28, 2006 04:26 PM
05mxdiesel
Oct 27, 2005 10:58 PM
