Shifting while towing
Old Nov 4, 2008 | 10:23 AM
m_gdavis's Avatar
I have a 2004.5 4x4 dually auto with a 4.10 axle truck that is all stock I live up a pretty steep hill and when I tow my 40ft (15000lb) trailer up the hill I have to get a really good run and right near the top it seems to be in second gear and lugging almost to a stop.
Can I use the shifter to drop it into first under this load? I haven't tried just using first the whole way up the hill.
Thanks
Old Nov 4, 2008 | 01:15 PM
92'1stGen's Avatar
I'd put it in first the whole way up so it never shifts out.
Old Nov 4, 2008 | 01:49 PM
madhat's Avatar
Administrator/Jarhead
Yeah, you can downshift, just let off the throttle. It should kick down on its own, tho.
It is an auto, right?
Old Nov 4, 2008 | 04:19 PM
m_gdavis's Avatar
It is a auto 4 speed.
When it is barely moving it sutters like it wants to go in first (or tranny slip) but never does. At least I hope its not in first. I'll try first gear the whole way this weekend. I just can't get the run (speed) I am use to. Also, if I have to back down it's a good .5 miles with curves. So it wouldn't be fun.
Thanks
Mike
Old Nov 4, 2008 | 05:36 PM
no_6_oh_no's Avatar
Thanks
Ummm, you have a fuel delivery or other problem that is causing this.
There is NO WAY you should be lugging the truck down with that load. It should be spinning the engine right thru the TC and not lugging.
Old Nov 4, 2008 | 05:44 PM
CamperAndy's Avatar
What kind of grade?? 4.10 you should have plenty of pull. Put it in second before you start and it will lock the TC and you should be able to rip up the hill. You could also have a fueling issue as said before, when was the last time you changed your fuel filter??
Old Nov 4, 2008 | 05:46 PM
STate's Avatar
a shudder or hunt between 1st and 2nd sometimes indicates a bad shift press. solenoid in the tranny, same thing happened to my 48re auto.
Old Nov 4, 2008 | 06:21 PM
bighornram's Avatar
I 2nd changing the fuel filter...
Old Nov 5, 2008 | 09:46 AM
m_gdavis's Avatar
The hill is probably a 20+% grade.
I did change me fuel filter about 6 months ago. I 'll change it again.
I don't expect to fly up the hill pulling 15000lbs I just want to make it without burning up the transmission. It is still under warrenty so I might take it in and complain it doesn't shift down to first under load.
Thanks for the help
Mike
Old Nov 5, 2008 | 10:45 AM
rip 112's Avatar
You need to change your filter preferably every 7-10 k on the stocker. If the grade is steep I wouldn't try shifting into anything while ascending, do what you will before you get to the hill. How many miles on the 48re? Maybe time for some servicing?
drewallen42
Apr 12, 2010 06:18 PM
Jturs
16
Aug 6, 2009 07:30 PM
solaman70592
Feb 28, 2006 03:47 PM
Jmac
Feb 22, 2006 04:11 AM
Valv
Apr 20, 2005 09:45 PM
