Removing Oil Filter - Not Full of Oil ???
Old Oct 2, 2011 | 01:32 PM
2005Turbo's Avatar
I have a 2005 Dodge 3500. I was changing the oil today, removed the Fleetguard LF16035 filter expecting the usual oil mess, I was surprised to find the filter was less than half full of used oil. This may be the first time I have used the StrataPore filter. No oil leaks, the engine does not use any oil. Anyone know what is going on?
Old Oct 2, 2011 | 01:40 PM
Hvytrkmech's Avatar
Absolutely normal, oil returning to the sump after shut downs draws down the filter. Your good to go.
Old Oct 2, 2011 | 03:51 PM
PoorMansCat's Avatar
x2... not an issue unless you enjoy oil running down your arm...
As a side note, the old plastic bag trick is by far the easiest way to not get oil on you when changing the filter...
Old Oct 2, 2011 | 03:53 PM
2005Turbo's Avatar
Thanks for the info! I wish it would do that every time. Makes for a lot less mess. Thanks again for hanging out here on Sunday to help folks out!!!
Old Oct 2, 2011 | 08:15 PM
AH64ID's Avatar
Let it sit overnight and it will happen every time.
Old Oct 2, 2011 | 09:58 PM
rockcrawler304's Avatar
True.
I try to get mine up to normal temp and then shut it down and let it sit for about 20 to 30 minutes and the filter is down about 1 inch and never a mess.
Old Oct 2, 2011 | 10:40 PM
BigIron70's Avatar
Cummins Guru
Yeah try doing that when you have 10 people waiting for their oil change to be done in 30 minutes or less. welcome to the real world.
Old Oct 2, 2011 | 11:13 PM
Been there and done that!
redlineguy
15
Jan 9, 2012 09:15 PM
13bdarren
Jan 27, 2009 12:39 PM
West Coast
Jul 4, 2007 10:25 AM
j
Nov 14, 2003 09:38 PM
