Purpose of High Idle in cold????
Old Nov 25, 2005 | 06:57 PM
Christov's Avatar
My '05 kicked up to a high idle of 1.000 RPM today after a few minutes of idle after a 40 mile trip in 14 degree weather. What is the purpose of the high idle??
I noticed it really dropped the temperature of the coolant gauge.
Thanks.
Old Nov 25, 2005 | 07:13 PM
Geico266's Avatar
It warms the engine up faster is all.
Old Nov 25, 2005 | 07:22 PM
trik396's Avatar
I started mine last night after being at a family get together where I was unable to plug her in. It was 15degrees outside. She started right away, but the cold made her sound labored a little. After a few minutes, idle kicked up to 1000rpms. Why didn't it do this immediately? Is there a way I can do it?
Also, I was able to hear/see the grid heater cycle on and off well after it was started.... is this normal?
Old Nov 25, 2005 | 07:53 PM
rammtuff's Avatar
High idle prevents wet stacking (cyl washdown)
Old Nov 25, 2005 | 08:08 PM
phox_mulder's Avatar
All perfectly normal.
It doesn't go into high idle right away because it needs to make sure that it is really cold enough, and it's not getting a false reading from one or more of the sensors.
Fer instance, one of the sensors is the coolant temp, it takes a while for the coolant to circulate and the reading to steady out.
Grid heats take a lot of juice, you'll hear the relays kick in, engine will sound different, volt meter will dip way down and exterior/interior lights will dim.
phox
Old Nov 25, 2005 | 08:13 PM
Cummins also have issues with the valves and push tubes getting gummed up with unburnt fuel after prolonged low temp idling, and end up sticking or getting bent. High Idle gets everything up to operating temp faster, and keeps it there to reduce the chance of this happening.
phox
Old Nov 25, 2005 | 08:29 PM
Christov's Avatar
Thanks for the replies everyone!! Much appreciated!!
Old Nov 25, 2005 | 09:40 PM
StrokeThisCTD's Avatar
get a bullydog downloader and the high idle is automatically enabled
i just hit cruise then set whenever i go in somewhere, even if the truck is warmed up. that way it stays warmed up and doesnt cool down or something if its really cold.
Old Nov 27, 2005 | 12:28 PM
Weaver7's Avatar
I just took my truck in for service the other day...I thought they reprogramed the ecu to do this? I never noticed that it idles up does it only do this at certain temps? Although this is the coldest weather we had since I purchased the truck back in July
05 2500
Old Nov 27, 2005 | 01:08 PM
AaronT's Avatar
You do not want higher rpm's immediately at start when cold. Need a couple of minutes to get the oil moving, then increase. Do not want to rupture a seal anywhere or make a scuff.
Old Nov 27, 2005 | 04:09 PM
trik396's Avatar
Very good point AaronT. Now it makes sense to me why it started, then after awhile the idle kicked up.... I feel stupid for not getting it sooner..
kicker210
Dec 2, 2009 08:23 AM
jmccart
Jun 12, 2007 02:12 PM
Ram1999
Feb 11, 2007 10:49 AM
Awall
Feb 1, 2007 06:52 AM
Mexstan
Sep 6, 2003 06:55 PM
