Noise in transmission HELP!!!
Old Jan 17, 2008 | 06:53 PM
Topper's Avatar
Hey guys,
I have a new noise in my transmission. It's not a high speed click click click like a universal it's more like a low speed clunck clunck. I only hear it in 6th gear. It happens even when the back tires are off the ground on jack stands. I have heard about 5 speeds having problems with a nut backing off or something but I don't remember anything about 6 speeds having problems.
Any help or input would sure be appreciated!
Thanks,
Topper
Old Jan 17, 2008 | 08:44 PM
Road Traveler's Avatar
Originally Posted by Topper
Hey guys,
Thanks,
Topper
Well I have a new clunk clunk as well and I could have swore it was in the tranny. I then thought it was a u joint but all of them check out fine. So I said the heck with it and run till it breaks. Then I started to get weird vibration so I went back to hunting the problem. Here is what I found out: it turns out to be the back drive shaft where it splines into the front drive shaft. You can hold the front one tight and in a bind and the back one will turn and twist inside the other one. When I gas it hard or suddenly back off the pedal it will clunk! Hope this helps!!
Old Jan 17, 2008 | 10:02 PM
j-fox's Avatar
Is it the clutch hub?
Old Jan 18, 2008 | 03:42 AM
Kman9090's Avatar
Seems like all the 2 piece driveshafts have troubles.
Old Jan 18, 2008 | 04:22 AM
Topper's Avatar
Thanks guys,
I will check over the drive shaft but it seems like it's only there when I'm in high gear. I guess I'll pull the drive shaft and then try it again. Does anyone know if the 6sp tranies had any trouble like the 5sp tranies did?
Thanks,
Topper
Old Jan 18, 2008 | 08:05 AM
roughstock's Avatar
what about the rear brakes?
Old Jan 18, 2008 | 11:44 AM
Topper's Avatar
Well guys,
I figured out what the noise was... NOT GOOD!!! I took the covers off the sides of the transmission and found a couple of gears with a tooth or 2 gone. I cleaned up the inside the best I could and ran a magnet in all the places I could and pulled out some scrap metal. Well I put it back together and refilled it. I took it for a test drive and the noise got real bad once I hit high gear. Yep this thing is toast. Anyone know a place that sells NV5600's??? Looks like it's time to open up the wallet.
Thanks for the replys guys. I wish you guys were right on this one.
See ya,
Topper
Old Jan 18, 2008 | 07:56 PM
tacohat's Avatar
If you are able to do the work yourself, I searched the internet for nv5600 parts. I found the following website that may have the parts you are looking for:
http://www.drivetrain.com/NV56000parts.htm
Otherwise, on ebay, they are asking upwards of $3000
Smkn600CTD
May 22, 2012 07:21 PM
Topper
Jan 26, 2008 11:39 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
1ST GEN.
Aug 5, 2005 10:29 PM
guzzirider
Apr 19, 2005 03:10 AM
