Loose Bajo Bolts
Loose Bajo Bolts
After picking up my truck from my servicing dealer and driving about 295 miles home. The truck was running rough and knocking. Upon inspection, I noticed the 2 banjo bolts loose.
I tightened them up and the truck in still idling rough, blowing black smoke on start up , and very loud knocking noise at the front of the engine.
My question is what damage is done?
What needs to be fixed.
The dealership is sending a truck and trailer over to pick it up and deliver a loaner.
No problems there.
My concern is engine damage?
Thanks Boris
No problems there.
Thanks Boris
Oil looks normal slightly low 1/2 quart maybe. No diesel smell that I can smell.
Knocking sound seems to be coming from the front top of engine.
The banjo bolts were only finger tight. My concern is with the bolts that loose, would the injector pump be sucking in air. And what damage will be done as a result of air being introduced through the bolts?
Thanks Boris
Thanks Boris
On the driver's side front of the engine, there is a plastic plug. Remove that and check the nut on the CP3 gear to make sure it is tight. If it isn;t, I'd request a new pump. Hard to tell if there was any damage to the pump or the pump shaft if it were left loose. Beyond that.......hard to tell.
Leaky Gasket
Aug 14, 2008 07:17 AM
Got Smoke?
Sep 11, 2006 10:23 PM
