new injectors or just new nozzels
Old Feb 2, 2008 | 02:12 AM
053500 07.52500's Avatar
I had some sludge and sand in my fuel tank which ended up taking out my lift pump and damaging the injectors in my 05 5.9 . The dealership says the injectors are running at 85-90 percent does anyone know if I was just to replace the nozzels will this fix the injectors or do they need to be completly replaced . Since I have never worked on the internals of an injector I dont know what all becomes damaged in them. Im puting on a 2 micron secondary filter since the factory filter dosent do much the lift pump is my fault but dodge should cover injectors when they have crap for a filtering system
Old Feb 2, 2008 | 07:19 AM
Rpainter's Avatar
I think if the injectors are in question of being damaged pull them and send them to formula one to be tested,new performance tips installed,and rebuilt if needed
Old Feb 2, 2008 | 08:44 AM
FarmerJim's Avatar
Times 2 on the Formula 1 suggestion. It was the best upgrade I made to my 03.
Old Feb 2, 2008 | 10:12 AM
Texan1983's Avatar
whats the cost on 6 injectors to be rebuilt?
Old Feb 2, 2008 | 10:19 AM
rich's Avatar
when did they start rebuilding them last i knew the machinery was to exspensive and that was last year
Old Feb 2, 2008 | 10:54 AM
Rpainter's Avatar
price depends on what size tips you use but to rebuild them price is 100 each but you have to buy his tips
Old Feb 2, 2008 | 03:09 PM
FarmerJim's Avatar
Price is $1100 for the tips and complete check out. Only rebuild if necessary. The F-1 injectors were one of the best upgrades I made on my truck. They really woke up the bottom end and I only got the 40hp for improved towing.
mx684
16
Jun 12, 2007 05:15 PM
mx684
May 18, 2007 05:43 PM
adidasman23
Nov 17, 2006 04:22 PM
dieselho
Feb 20, 2005 09:33 AM
