Any tips for engine removal.. ???
Old Feb 1, 2008 | 06:55 PM
Checkmate's Avatar
So I am getting ready to pull the engine to have the bottom end freshened up because of an assumed rod knock. What are some tips to make this go easy. I haven't pulled a diesel engine out of a newer Dodge (this is a good thing ) and any help greatly appreciated. What to remove, What not to remove, Where to lift, etc. etc.
Also, while I have the engine out, what are some things to look at / replace. The engine has 204,000 miles on it. Should I worry about the oil pump ?
Thanks, dan
Old Feb 1, 2008 | 07:49 PM
06RAM2500's Avatar
Take your time for one. Before you do pull it, make dang sure that it's free from the truck, i.e.. bolts, elec. connections. Being it has that many miles, I'd try and do a complete rebuild, especially with a rod knock. God knows how much metal is in there. Replace all hoses, accessory belt, engine mounts, front seal on the transmission, flush the radiator, power steering, use new coolant.
Old Feb 2, 2008 | 10:22 AM
rich's Avatar
hood all of the front grill has to come off, also pull the head off seperate due to the weight it aint light
Old Feb 2, 2008 | 05:39 PM
Checkmate's Avatar
because of the weight issue I was gonna use a 1 ton chain hoist. Any cons to using it? Thanks
sallyman1
30
Mar 28, 2009 05:28 AM
1qckdodge
Oct 16, 2007 10:32 PM
Neal Cassady
14
Jan 28, 2006 08:39 AM
janb
Oct 9, 2005 03:36 AM
