Drag Link removal tips? W350
I seem to have a shimmy... (~30mph, worse when braking if front end is light do to heavy load or going across angled railroad tracks) only loose part is frt joint on Drag link. (barely little play)
I know these can be a bear to remove.
I would also like to know a 'none destructive' way, as I have a newer one on a '78 1T that I am parting out.
I used a pickle fork last time, but broke it (the tool) and fork usually trashes the rubber boot. On some of my 'wimpier' autos, a swift simultanious smack on opposing sides of part w/ tapered hole works pretty well.
I am relatively new to these forums and I am also the proud new owner of my first cummins truck, but the symptoms you are describing remind me of a time when one of my front shocks went bad on my old lifted blazer. It had the exact same symptoms and since the shock was lifetime warranty, it cost nothing but a couple of bolts and a really interesting ride to the local 4x4 shop to replace it. Problem solved.
matt1969
Jun 21, 2007 09:06 PM
sennbj
Mar 16, 2003 11:11 AM
