Axle flange bolts working loose on D80?
Old Sep 10, 2006 | 11:34 PM
Got Smoke?'s Avatar
I'm having a problem keeping the right rear axle flange bolts tightened on my truck. Had some rear end work done 2 months ago and he had to heat up the hub to remove two snapped flange bolts, but he replaced all of the bolts with grade 8 hardware on both sides.
Now twice in about two months I've had all 8 axle flange bolts work their way finger loose and start leaking gear oil badly. The first time I used red lock tight and an impact, now less than a month later its happened again.
Any ideas? The drivers side hasn't given me any problems?!?!
Old Sep 11, 2006 | 12:02 AM
GSP's Avatar
GSP
Loose bearings? Hate to think of anything worse...
Old Sep 11, 2006 | 12:14 AM
Got Smoke?'s Avatar
How would loose bearings allow the axle flange bolts to come loose?
Old Sep 11, 2006 | 10:23 PM
dslpower's Avatar
By constant wobbling if the tire/wheel assy is even slightly out of balance. Throw some lock washers on it, my M/H has internal star lock washers on the axle bolts.
jklidy
Mar 11, 2010 08:52 AM
getblown5.9
Jun 25, 2007 12:06 AM
dieselfuelonly
18
May 24, 2007 09:01 PM
Common
Mar 11, 2007 10:44 AM
