lift pump
Old Jan 23, 2010 | 07:31 PM
roadstarjr's Avatar
lift pump
Anyone know about this pump?
http://www.blueridgediesel.com/shopc...?products_id=7
Old Jan 25, 2010 | 03:30 PM
roadstarjr's Avatar
Bump Anybody ?
Old Jan 25, 2010 | 03:40 PM
cbrahs's Avatar
if you are looking for a stock replacement, you can get on dodgeparts.com and find a complete unit for less than that.
Old Jan 25, 2010 | 04:09 PM
Dr.Dizzle's Avatar
If you are looking to perform a one for one replacement of the cannister mounted unit,the following link contains a pump that is cost effective
http://www.genosgarage.com/prodinfo....UMP_FPD4089602
Old Jan 25, 2010 | 05:12 PM
tajinate's Avatar
That's a better price, but go on rockauto.com, they have the stock replacement one listed for $153.79 if that's what you want to do.
Old Jan 26, 2010 | 12:01 AM
Stew130's Avatar
got mine from Geno's and it only took me less than 1 hour from the time the hood went up 'til I closed it back. I've got almost 15k on it so far with no problems. Almost easier than changing the oil...
Old Jan 26, 2010 | 12:50 PM
billie's Avatar
FYI, we just broke down an 03 factory lift pump and the cause of failure was one of the motor brushes. It was totally gone with just a wire left. Failed at about 70K miles. The design has the motor totally submerged in fuel and a spiral vane impeller. No evidence of any other problem or excessive wear.
Has anyone stripped down an in-tank (or any other type) after a failure to see the cause?
Old Jan 26, 2010 | 12:57 PM
tajinate's Avatar
What did the other brush look like?
Old Jan 26, 2010 | 01:17 PM
billie's Avatar
Actually looked almost new. We didn't track down which was + and which was -.
Old Jan 26, 2010 | 01:55 PM
stock03's Avatar
Are you going to rebuild it? I changed my stock LP at about 80k miles, and I still have it as a spare. It would be nice if there was a simple rebuild kit for the stock lift pump.
Old Jan 26, 2010 | 05:23 PM
billie's Avatar
Not the one we took apart We had to bust the housing.
Old Jan 26, 2010 | 07:39 PM
tajinate's Avatar
I was wondering about that, I thought they weren't serviceable and figured it had to be destroyed to get a good look at the guts.
Old Jan 27, 2010 | 07:44 AM
AlCorr's Avatar
Did you remove the lift pump from the top or from under the truck. There doesn't look like there is enough room to get at it from the top. Any advice or hints on how to install a new stock lift pump?
Old Jan 27, 2010 | 08:00 AM
kevin.yoakum's Avatar
The instructions that come with the pump from Geno's are very good, I removed mine from the top no problem just four allen head bolts. Complete replacement in less than an hour, that includes time to find rubber gloves and tools.
Old Jan 27, 2010 | 07:31 PM
roadstarjr's Avatar
Well I got mine changed out tue. about and hour and after reading all kinds of stuff. I went with the Geno's replacement and I'm going to get one more from rock auto for 20.00 less and put under rear seat. I couldn't see doing the dodge thing for 900.00 or the Raptor RP100 for 460.00 or any of the other things I could have done for a lot more cash.
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
