Guys, Please help me diagnose a problem...
Old Jan 27, 2010 | 03:28 PM
needaram's Avatar
At idle my truck has a juingling sound coming from the front of the motor. It's a metallic sound like a pulley is loose or something. I cannot hear it from the cab but it is very noticeable if I walk to the front of the truck. I've heard it could be the tensioner. If it is how easy is that to replace? The truck runs great and the guages all show normal numbers. The truck has 107,000 miles. thanks a bunch
Old Jan 27, 2010 | 03:49 PM
billie's Avatar
Does it change with RPM? Start with taking off your serp belt and look for loose pulleys. There should be NO sideways (wiggle) play. The tesioner and the idler pulley are likely culprits and both are easy to change. If those are good the next to check are the AC and fan since they have clutches in them. Check your belt for damage too.
Old Jan 27, 2010 | 06:06 PM
Hvytrkmech's Avatar
I would inspect the tensioner and pulley's asap. They are not that hard to change out. The belt will give the majority of difficulty taking it of and putting it on.
Old Jan 27, 2010 | 06:10 PM
cameroneod's Avatar
The tensioner will usually bounce around when it is starting to go. VERY easy to change. I did mine a few weeks ago and it took around 20 minutes.
Old Jan 27, 2010 | 06:11 PM
needaram's Avatar
I'm gonna check em all tomorrow guys. Would auto zone carry these parts or do I need to go to the dealer? I probably won't have time to order because I really need to be in the road. thanks fellas
Old Jan 27, 2010 | 06:18 PM
billie's Avatar
Lots of places have them, on the shelf.
Old Jan 27, 2010 | 06:20 PM
needaram's Avatar
I just called my local auto zone and they have one for 100 bucks. I hope thats what it is. Thanks again
Old Jan 27, 2010 | 06:29 PM
Hvytrkmech's Avatar
Change the belt while you are at it.
Old Jan 27, 2010 | 07:02 PM
needaram's Avatar
will do. anything else on this truck I should take a look at guys?
Old Jan 27, 2010 | 07:26 PM
hawkeye759's Avatar
Check the water pump too. Mine made the same noise when it went out.
Old Jan 27, 2010 | 10:49 PM
MoparNut's Avatar
Mine had a similar noise. Kind of a mix of a ticking and rattling. Tighten the little blue clamps on the fuel lines and it's gone. Give it try, it's free. Don't torque on them just snug them up.
Old Jan 27, 2010 | 11:51 PM
littlebigtruck's Avatar
Smile
If it's you idler pulley you can replace just the bearing, same way with the fan pulley bearing if you have access to a press. If I recall correctly I go the idler bearing from NAPA for about 12$ and the fan pulley bearing was around 84$ I think. Just a tip to save you some money.
adamkn
20
Jan 9, 2013 12:30 PM
mr-walleye
Dec 3, 2008 07:42 PM
bigragu
Sep 24, 2007 06:45 PM
Gunpowder
16
Jan 17, 2007 10:02 PM
4x4dually
Mar 2, 2005 04:17 PM
