Lift pump on a 03
Old Jan 6, 2009 | 10:21 AM
BlueOx1's Avatar
Lift pump on a 03
Hey guy's I think the lift pump on the truck is failing because anytime I go to put a load on it ,it falls on it's face around 2000 rpms and rpms won't go up after that, you have to back out of the throttle and let the fuel catch up it seems like .I tried the fuel filter in a last ditch effort no change (didn't think it would help but was time to change it anyway) in driving.I don't have a code, I'm looking around to find a pressure gauge to check the cp-3 ,also the lift pump sounds pretty rough and when first turned on for the Wts light the pump just runs and runs and doesn't shut off like it isn't building enough pressure.I was just wondering if anyone else has had symptoms like this with there truck.
Old Jan 6, 2009 | 10:38 AM
Grey Wolf's Avatar
Thumbs up
No problems here but here's a good solution
https://www.dieseltruckresource.com/...ment.php?f=102
Old Jan 6, 2009 | 10:59 AM
BlueOx1's Avatar
Update - lift pump bad just ordered a raptor 100 from dtr store so hopefully get's here fast .
Old Jan 6, 2009 | 12:09 PM
MikeyB's Avatar
Excellent choice!
MikeyB
Old Jan 6, 2009 | 05:43 PM
BlueOx1's Avatar
Mikey how long did it take to install the raptor 100 and is the pressure preset from the factory ,I don't have a fuel pressure gauge( I know a big sin )What will it be set at?
Old Jan 6, 2009 | 09:06 PM
han solo's Avatar
My raptor 100 came preset from them @ 15psi, according to my fuel pressure gauge. I take the reading @ the inlet of the CP3. You can adjust pressure if you want on with a wrench & screwdriver. Nice thing with the 100, hook the 1/2 hose to the supplied dorman fitting, clips to the tank outlet. There is no return line to mess with. Unless you have a intank fuel pump updated by a dealer? If so you will need an old style fuel cannister.
Old Jan 7, 2009 | 07:15 AM
MikeyB's Avatar
Han Solo pretty much nailed it.
Took me about two hours to install with simple hand tools. Here's a trick to help get the hoses onto the Parker Pushlok fittings. Either soak the ends of the hoses in hot water or use a hot air gun before pressing on. Makes it a whole lot easier.
MikeyB
Old Jan 7, 2009 | 09:08 AM
BlueOx1's Avatar
Thank's guy's I have the canister mounted lift pump that's kind of why I went with the raptor is the easy hookup.
Old Jan 7, 2009 | 11:02 AM
El Borrego's Avatar
My '03 lift pump failed a couple of years ago. Dealers kept telling me it was the Edge unit I installed. Wrong. Put it on a dyno and when loaded with 10K pounds on a 6 percent incline, fuel pressure went to zero. Put in-tank pump in it and have not had any fuel problems since. Another one of those Dodge knows about it but won't make it a recall item.
Old Jan 7, 2009 | 02:46 PM
BlueOx1's Avatar
Tell me about it ,easier to blame something else.
Old Jan 7, 2009 | 10:37 PM
han solo's Avatar
You said you have a cannister mounted lift pump? Its not on the motor anymore? If its been up dated, & put into the tank, you will need to get an old fuel cannister from a 03/04.5. Glacier sells them. From what I have read, cant have the stock fuel pump in the tank. They sell used ones for $100bucks, comes clean & checked out. Dealer doesnt sell them anymore. Good tip MikeyB about the holes, there a bear to get on. Im not going to get into the removing air issue. I just wanted a good pump, without a standpipe & the 1/4 tank issues. Dont ever plan to break into the 600hp club. So thats why I went with the Raptor 100. Run the supplied 1/2 hose from the tank to the raptor, then to the backside of the stock fuel filter. Then put on a secondary fuel filter @ 2micron, its inbetween the stock housing & the CP3, where I get fuel pressure from. I dont like the fuel filters under the truck, behind the transfercase. Thats why I didnt go with the air dog, but thats just me. The airdog is likely a awesome setup, but I got a smoking deal on the Raptor.
Old Jan 8, 2009 | 08:59 AM
BlueOx1's Avatar
It's the one on the engine,it sounds easy enough to do now to get the truck in the garage will it hurt the cp3 if I fill the fuel filter and try and drive it to the garage ?I would like to take to my Dads the heated garage would make it nice .
Old Jan 9, 2009 | 12:38 AM
han solo's Avatar
Your laughing then if the pump is on the engine. If your small enough, you could wiggle under the box, & get to the top of the tank. Unhook the supply line, then hook up the dorman fitting that goes in the kit & then run the fuel line to the raptor/engine. Dont know about your problem thou, cant say how far it would go.
Old Jan 9, 2009 | 03:23 PM
BlueOx1's Avatar
Just finished up the install took 3 1/2 hrs ,had a river coming down on me from the snow melting.Hardest part was the Dorman fitting on the tank other than that wasn't to bad .
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
