How much oil is lost when changing a turbo?
Old Dec 24, 2008 | 01:08 PM
Roperteacher's Avatar
I went by the dealer to see if an oil change came included with turbo replacement. They looked it up and NO, does not. The book says to TOP OFF any lost oil while doing the change. I guarentee you they do not carry the oil I use to top it off with and I don't like running an oil MIXTURE. I guess I will just change it as soon as they get the turbo done. UNLESS, you don't lose any/much. SO how much is typically lost during this process? Thanks!
Old Dec 24, 2008 | 01:15 PM
jeff-kc9ftp's Avatar
very little
maybe an ounce or two, if that.
a little more if you forget to tighten the drain tube bolts ,oops.
jeff s.
Old Dec 24, 2008 | 01:59 PM
WhoozYaDaddy's Avatar
why are you changing the turbo?
Old Dec 24, 2008 | 02:35 PM
rich's Avatar
if your changeing the turbo it sure wouldnt hurt to change the oil just incase anything is in it
Old Dec 24, 2008 | 02:49 PM
If you read another thread on this same forum, the dealer is changing out my turbo because I lost the Internal seals ay 40,000 miles. Well, they haven't 100% gone, but I have seepage out the BACK of the turbo and my intercooler hose is moist with oil. They are replacing it Tuesday. I will just do an oil change as soon as I drive it home from the dealer on Tuesday. Your right, just in case they got anything in there.
Old Dec 24, 2008 | 07:52 PM
Spooler's Avatar
When I upgraded my turbo I changed the oil after I did the swap. It was time anyway and won't hurt if you do.
Old Dec 24, 2008 | 09:16 PM
OOPS's Avatar
When my Turbo went out the dealer changed the oil, oil filter and fuel filter for free. Maybe they did it because the bearings went south in the Turbo and started to come apart.
Old Dec 25, 2008 | 06:34 AM
Hounddog's Avatar
Replacing a turbo because of bearing failure is different then replacing one for soot or external seal leakage.Won't lose but a very small amount of oil.hats why warranty pays for oil/filter on some warranty ops and other ops they don't.Its a common sense thing.
Old Dec 25, 2008 | 08:59 PM
trx's Avatar
trx
When I installed a new turbo instructions suggested to do an oil change at the same time. Best not to put contaiminated oil through your new turbo for what its worth.
Old Dec 26, 2008 | 09:41 AM
Truck will get Fresh oil 6 miles after the repair! Thanks for the info!
Old Dec 26, 2008 | 09:50 AM
Ron Barker's Avatar
this thread can't be for real... right?
Old Dec 26, 2008 | 06:56 PM
Why wouldn't it be real? Yep, it's real!
Old Dec 26, 2008 | 07:53 PM
Ron Barker's Avatar
I thought I missed the joke... you shouldn't lose more than a few drops of oil on a turbo swap
Old Dec 26, 2008 | 09:09 PM
Bark's Avatar
Roperteacher: They did not change the oil for me either. They should have just to even things up for me having to wait many weeks for the new (to me) turbo to show up. Speaking of which, did you get a new turbo or a rebuilt?
Old Dec 26, 2008 | 09:32 PM
Ron Barker's Avatar
I'm assuming his truck is a 6.7... either way, it would have been replaced with a new unit
cincydiesel
May 19, 2009 09:39 AM
klx650a2
Sep 19, 2008 09:28 PM
Jdoneff
22
Mar 5, 2008 03:13 PM
92DIESEL
May 27, 2005 12:20 AM
j
Jan 9, 2004 08:19 AM
