HOAT Rated Coolant
Old Dec 11, 2008 | 04:36 PM
  #61
hoot's Avatar
Old Dec 12, 2008 | 03:36 AM
  #62
ratsun's Avatar
Originally Posted by hoot
Sure would be nice if it wasn't clear
Tough to tell when you got a leak
Old Dec 12, 2008 | 08:58 AM
  #63
BMH95's Avatar
I use Fleetguards red extended life stuff. It's supposed to go 600K miles, so I'm good for life. I figure if it's good enough for OTR trucks and Cummins motors then it's good enough for me.
Old Dec 12, 2008 | 10:25 AM
  #64
HOBrian's Avatar
What did that cost a gal.?
Old Dec 12, 2008 | 01:40 PM
  #65
kry226's Avatar
I have read that pulling the thermostat and blowing compressed air into the orifice will help push remaining fluid out of the block. FWIW.
Old Dec 15, 2008 | 09:28 AM
  #66
BMH95's Avatar
It was close to $20/gallon. Here's the literature on Fleetguard ES Optimax. Notice the organic acid information.
"FLEETGUARD ES Optimax™ EG Antifreeze/Coolants are Extended Life formulations that contain Ethylene Glycol base fluids and are designed specifically for use in heavy-duty diesel engines. ES Optimax™ EG Antifreeze Coolants are fully formulated with Organic Acid Inhibitors, and provide superior liner pitting and corrosion protection in diesel engines. ES Optimax™ antifreeze/coolants are phosphate, borate, amine, and silicate free, and contain proprietary anti-scale additives that eliminate the need for deionized water.
FLEETGUARD ES Optimax™ EG Concentrate mixes readily with clean tap water or demineralized water, while ES Optimax™ EG Premix is formulated with demineralized water and is ready to use. ES Optimax™ coolants are compatible with conventional antifreeze products and liquid SCA’s and standard water filters; however, mixing with conventional antifreeze may reduce the extended life characteristics of the product. ES Optimax™ EG Antifreezes are universal products highly recommended for use in all heavy-duty diesel engines, and also for use in automobile and light duty applications.
FLEETGUARD ES Optimax™ EG Antifreeze Coolants meet or exceed the performance requirements of the following specifications."
Here's a link to a site that has all the info you need:
http://www.terrabond.net/Files/Menus/ESOptimaxEG.pdf
traverler48
Jan 9, 2011 07:38 PM
mstep3
May 4, 2010 08:33 AM
dirtygoat
Mar 3, 2010 02:08 PM
papaduck
16
May 3, 2007 08:17 AM
1stTimeAround
Jul 26, 2006 11:50 AM
