HOAT Rated Coolant
Old Mar 11, 2008 | 09:11 AM
  #46
enafzige's Avatar
Is this for sure!!! I just bought G05 Zerex and it is yellow. My reservoir is on the low side when cool but I can see it is orange/red. I suppose the two are compatable??
And I just bought G05 Zerex this weekend and it was clear!!! I found mine at Napa fwiw. Cost was $14.95/gallon.
--Eric
Old Mar 11, 2008 | 10:15 AM
  #47
Jeff in TD's Avatar
Click on the FAQ button, and it says Chrysler has used G-05 as factory fill from 01 on died orange.
http://www.valvoline.com/pages/produ...asp?product=10
Old Mar 11, 2008 | 04:54 PM
  #48
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
My manual states; ethylene glycol - not propylene glycol
This is in the '03 manual
Old Mar 11, 2008 | 06:38 PM
  #49
Jeff in TD's Avatar
Zerex G05 is ethylene glycol.
Old Mar 11, 2008 | 06:44 PM
  #50
Pull Dog's Avatar
I got on the Zerex web site and found a phone number for technical support. When I called them a technican told me yes GO5 Zerex is the same thing that came in my 05 Cummins, they just supply it with a different dye which is interchangeable with other colors of G05. I bet a lot of people will fall victum to this color deal and use orange Prestone. READ YOUR OWNERS MANUAL!! HOAT ONLY!!
Old Mar 11, 2008 | 08:09 PM
  #51
Eat Beef's Avatar
From that info I understand that any coolant that is ethylene glycol is okay to use..??
Old Mar 11, 2008 | 08:28 PM
  #52
Jeff in TD's Avatar
Ethylene Glycol with Hybrid Organic Acid Technology (HOAT).
Old Mar 23, 2008 | 11:16 AM
  #53
Nate-03 D's Avatar
Does anyone have a good link or a write up on the coolant change? Mainly the specs?
My local NAPA carries the Zerex G-05. I asked the guy if it was HOAT rated and he gave me a blank stare. I read the label and it did state it was ok for diesels and Cummins was under that list.
As I read this thread I came to the conclusion that you can't realy drain the entire cooling system by just pulling the drain, you will always have some left over?
Old Mar 23, 2008 | 03:18 PM
  #54
Jeff in TD's Avatar
What specs did you need?
My method, anyway, is to drain the radiator in a bucket and flush it. Then I like to set the heater on hot, and undo a heater hose (whichever is handy), and hold a garden hose up to one end, then the other, until the water overflows the radiator cap and runs clear.
Then let it drain, close the drain, then pour in anti-freeze equal to a bit more than 1/2 the listed cooling system capaicty from the manual. Top the rest off with distilled water.
For the overflow tank, you can often pull the hose and hold it below the tank. You can then put a garden hose running hard in the top of the tank, and it will generally push fluid out the hose, which will start it syphoning to empty the overflow tank. Then hook it's hose back up and fill it with anti-freeze and distilled water.
The first few heating and cooling cycles will push air out of the radiator and draw coolant from the overflow bottle back in, so keep an eye on the level and add as needed.
Old Mar 23, 2008 | 05:45 PM
  #55
Nate-03 D's Avatar
Sounds pretty simple.
If I already buy the 50/50 mix why would you need to top the rest off w/ distilled water?
Old Mar 23, 2008 | 08:41 PM
  #56
Jeff in TD's Avatar
I'm not a big fan of using the 50/50 premixed stuff if you are going to flush it out with plain water.
IMHO as long as you are spending the time and money to change the coolant, it makes sense to rinse the deposits and all the old stuff out.
There can be a gallon or more of plain water in low spots that won't drain out, so you can end up getting a weaker than intended anti-freeze concentration if you refill with 50/50 premix.
I had that happen once with a gas motor, and the result got slushy in the winter. Ever since, I've always added the proper volume of anti-freeze to obtain the concentration I needed, based on the cooling system capacity, and top off with distilled water, and I've never had any other problems.
When I did the coolant on my 03, I didn't use use all the distilled water I had bought, so I know quite a bit of water was left in low spots. Having a little bit of tap water in there isn't a problem, but having an anti-freeze concentration too weak to provide freeze, boil, and/or corrosion protection would be...
Anyhow, this is just what works for me...
Old Mar 24, 2008 | 09:21 AM
  #57
05HDRAM's Avatar
Why are you bothering with distilled water if you are flushing with a garden hose. There is no way you are getting all of that water out.
Old Mar 24, 2008 | 04:39 PM
  #58
Jeff in TD's Avatar
I suppose a person could flush it with distilled water, but I don't really think the little bit of tap water that doesn't drain out will hurt anything...
JMHO.
Old Mar 24, 2008 | 07:00 PM
  #59
papaduck's Avatar
I used water saved from A/C runoff from the house to flush and refill. At least there are no minerals in this water and it cost nothing.
Old Mar 24, 2008 | 08:44 PM
  #60
fredbert's Avatar
I was having trouble finding Zerex antifreeze/coolant and SynPower gear oil, so I E-mailed Valvoline. They were very responsive, telling me NAPA is the best bet for all things Valvoline and that if they don't have it, they can order it. Sure enough, that's where I found it!
