HOAT Coolant
Old Mar 2, 2010 | 11:01 AM
dirtygoat's Avatar
HOAT Coolant
How important is it to run the HOAT equivelant coolant in the cummins engine? I had to make a last minute decision due to availability of coolant. I do intend on switching to a HOAT equivelant coolant in the near future. Is there anything to be worried about?
Old Mar 2, 2010 | 11:29 AM
shonne's Avatar
I think the big thing is knowing what you mixed with it. I have always been very paranoid about mixing coolants. HOAT (Hybrid Organic Acid Technology) refers to a specific inhibitor package in the coolant itself. There are alternatives to HOAT. I am running Fleetguard ES Compleat™ OAT.
I see you are in Pflugerville. I am Hutto.
Hello neighbor.
Old Mar 2, 2010 | 08:23 PM
kry226's Avatar
Agreed. The MOST important thing is ensure there is no mixing of different types of coolant.
Old Mar 2, 2010 | 08:47 PM
bansh-eman's Avatar
Do some searching. Dr. Drizzle has covered this topic in depth of wh you need to use HOAT
Old Mar 3, 2010 | 08:12 AM
rufushusky's Avatar
The guy I talked to at Cummins northeast said that Dodge required HOAT coolant due to the greater use of Aluminum in their vechiles, eg. the cylinder heads on the new hemi. I think so long as you completely flush the old coolant you can run a diesel rate low silicate coolant just fine.
Old Mar 3, 2010 | 10:53 AM
Jeff in TD's Avatar
A buddy of mine who used to run a radiator shop once told me if he owned it, it would be hoat while under warranty, then flushed and run with tradational chemistry changed every two years...
Old Mar 3, 2010 | 02:08 PM
dirtygoat's Avatar
Thanks for all the info...
traverler48
Jan 9, 2011 07:38 PM
mstep3
May 4, 2010 08:33 AM
mjsandt
65
Dec 15, 2008 09:28 AM
papaduck
16
May 3, 2007 08:17 AM
1stTimeAround
Jul 26, 2006 11:50 AM
