High Idle
Old Apr 20, 2005 | 10:41 PM
wagonhauler's Avatar
High Idle
Does anyone know how to turn on the high idle where you use the cruise control
Old Apr 20, 2005 | 11:58 PM
J BODY's Avatar
Yes.....for you to do it you have to go see a salesman about trading up to an 04. 03 still had old school electronics so you're stuck with a piece of broom stick like me to get that "high idle".
Old Apr 21, 2005 | 04:27 PM
4x4not's Avatar
Since I'm new to the Cummins, how do you get this high idle with the 04+? The search function isn't working...
Old Apr 21, 2005 | 04:35 PM
underwoodtransp's Avatar
if your truck is capable of it. some are not programmed from the factory with it. You fire it up and just hit the cruise on/off button and then hit the set button. This needs to be done fairly quickly so don't waste any time between buttons. Then you can adjust how high with the accel/decel buttons. it only goes to 1500rpm. If your truck doesn't do it bring it into the dealer with a complaint of "does not produce heat or a/c at idle" that exact complaint will get your truck reprogrammed for free, otherwise you will have to pay for a "reflash" if you tell them you want the high idle. I was told that by a tech at the dealer when I bought my truck. Luckily mine was setup from the get-go. good luck!
Old Apr 21, 2005 | 04:47 PM
4x4not's Avatar
Thanks! I'll try it when I leave work in 15 minutes
Old Apr 21, 2005 | 04:57 PM
bulabula's Avatar
The high idle function only works with automatic transmission trucks.
If its not already enabled, the dealer has to go into the ECM and enable that function - you or may not be charged a fee.
Old Apr 21, 2005 | 05:09 PM
Mopardan's Avatar
They did mine for free last year. I carried a copy of the TSB that I got off of this site. Told them I had poor cab heat. Took about 10 min.
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
