fluid types and capacities
Old Apr 4, 2005 | 09:07 PM
bluebull's Avatar
Where to find fluid types, capacities, and where to find them for my truck. I like to research things in advance before buying so I can find the best deals. Owners manual is vauge about capacities and equivilant fluids.
I am looking for:
1. atf+4 besides chrysler type for transfer case.
2. NV5600 gear oil.
3. gear oil for 11.5 rear and front axle fluid.
Old Apr 4, 2005 | 09:16 PM
bulabula's Avatar
Re: fluid types and capacities
I am looking for:
2. NV5600 gear oil.
Part of your research should be to review some recent threads in this forum to quench your thirst for knowledge. Here's three recent ones ...
https://www.dieseltruckresource.com/...threadid=65011
https://www.dieseltruckresource.com/...threadid=64814
https://www.dieseltruckresource.com/...threadid=64579
You could also use the search feature provided on the site.
Old Apr 5, 2005 | 07:04 AM
LinearX's Avatar
I am looking for:
2. NV5600 gear oil.
I can't do much for equivalent types for ATF+4 as I used the stuff at the dealer. Pennzoil makes a fluid for the NV5600 as does Redline, but again I used the factory stuff. I used Mobil 1 75W90 in the front and rear differentials. Now for capacities:
1. Transfer case -- 4 pints = 2 quarts
2. NV5600 -- 9.5 pints = 4.75 quarts
3. Rear differential -- 7.65 pints = 3.825 quarts
4. Front differential -- 4.75 pints = 2.375 quarts
I'm sure these are not 100% exact, but this is what the service manual lists as capacities for each.
Old Apr 5, 2005 | 07:15 AM
bluebull's Avatar
Thank You, Do you know the name of the pennzoil stuff.
After reading some of the threads above am I correct to assume:
I can use just about any fluid as long as it is synthetic in any one of the three questions I asked?
Old Apr 5, 2005 | 07:21 AM
rossn2's Avatar
I sent you a pm with some specs and oil info...
Old Apr 5, 2005 | 07:28 AM
bluebull's Avatar
rossn2,
I would appreciate very much. E-mail has been sent.
Thank You.
Old Apr 5, 2005 | 07:50 AM
kry226's Avatar
Be sure to plan for extra fluid capacity. For example T-Case calls for 2 qts, mine held 2.5 qts.
Old Apr 5, 2005 | 08:02 AM
LinearX's Avatar
Pennzoil Synchromesh is the name of the fluid they make. I have no clue where to get it, though, that's why I went with the factory stuff.
All of the fluids for the transmission and differentials are synthetic, however I have no clue about the ATF+4. I just got what the dealer had as I was unable to find any good cross reference for it.
Old Apr 5, 2005 | 01:07 PM
rossn2's Avatar
Engine Oil (11 Qts/ 12 w/filter)
Eng. Oil Filter (1 Qt) Mopar 05083285AA ($11.38) Amsoil SDF-80(13.85) FleetGuard LF-3972 / Stratapore LF 16035(9.35)
Eng Air Filter Mopar=AF53032700AA Amsoil=Recharge Kit AF-BC (2.80)/TS 189 Filter ($35.00)
Transfer Case (up to 5pts/3qts) Mopar ATF+4 ATF Amsoil=Synthetic Universal Automatic(ATF$7.80qt)
Man. Trans. NV 5600 ( 6 Spd 9.5 pts/6 qts) Mopar=Manual Fluid 4874464 REDLINE MTL $7.00 per quart
QuakerState & Pennzoil Syncromesh (Meets Factory fill specs)
Frt & Rear Axle (up to 5 pts frt & 8pts rear/8 qts) GL-5 SAE 75W-90 Synthetic. NO ADDITIVE. Amsoil=Gear Lube 2000 75w-90(TGR$9.20qt/)
Redline 75w-90 Gear Oil/ $7.00 quart
Mobil 1 Synthetic Gear Lube
LS 75W-90 & Valvoline Full Synthetic Gear Oil 75W-90
Engine Fuel Filter Mopar=5015581AB FleetGuard= FF1093($13.20) FS19579 (11.95)
Old Apr 6, 2005 | 07:27 AM
bluebull's Avatar
Thanks,
bringing it back TTT so everyone can have the info.
Thanks again to everyone.
Old Apr 21, 2005 | 07:32 PM
cwg's Avatar
cwg
Thumbs down
after putting it off for way to long (31k) I changed my rear differential fluid this afternoon for the first time. I went to AutoZone and picked up 4qts of Mobil 1 Synthetic 75w-90. when I got home I pulled the cover and let it drain into a small clean drain bucket. the fluid was still warm and I let it drain for an hour. I even jacked up the front of the truck to make sure I got it all out. after cleaning and reinstalling the cover I filled it with 3.8qts of fluid.
here's where it gets funny. I dumped the extra 5oz of fluid into a different drain bucket so I would have 4 empty 1 qt bottles to drain the old fluid back into. I put 32oz in 3 of the bottles and only 5oz in the forth. that's only 3.15qts of fluid in a rear differential that requires 3.8qts. there were no leaks, the fluid was still fairly clean and the ring and pinion showed a normal wear pattern so I'm not to worried about anything.
is it that hard for dodge to put the correct amount of fluid in our trucks from the factory?
VaultRam
May 28, 2008 07:56 PM
24seven
May 17, 2007 11:08 PM
moore54
Mar 9, 2006 02:36 PM
truckjunkie
Jul 30, 2005 04:02 PM
bdog
Dec 18, 2002 05:55 PM
