High Idle
Old Jan 4, 2009 | 09:40 AM
pete97's Avatar
High Idle
I had the dealer activate the high idle feature through the cruise control. When they first did it a couple months ago I could increase the idle starting at 1000 rpms by pressing the set button. Now it will only increase to 1000 rpms and won't go any higher. Any suggestions??? I'm going to stop at the dealer tomorrow and see what they say. Pete
Old Jan 4, 2009 | 09:46 AM
huntr70's Avatar
Pressing the set button will activate the high idle with the cruise control.
You use the increase or decrease buttons on the other side of the wheel to adjust RPM up to 1500......
Old Jan 4, 2009 | 11:29 AM
pete97's Avatar
Ok thanks. Maybe I hit the wrong button. They never explained it to me when i left the dealership. Pete
Old Jan 4, 2009 | 03:31 PM
bigjohn04's Avatar
For your info to use the high idle turn the cruise on and hit set and it will go to 1100 rpm and then you can use the res/accel to raise the rpm and the coast button to lower it.
Hope this helps.
Old Jan 4, 2009 | 11:15 PM
AlK's Avatar
AlK
Ditto. what bigjohn04 said.
Old Jan 5, 2009 | 09:47 AM
Neight's Avatar
What did you tell the dealer you wanted done? A friend of mine went to the dealer to have them activate his and they said they had no clue what he was talking about.
Old Jan 5, 2009 | 03:34 PM
moterhead's Avatar
Look at the top of this screen. You will see a button marked "Articles". It's between Member Photos and LInks. Click on that. Go down the screen a ways. You'll see a listing for enabling the high idle feature. Click on that. It will bring up a copy of the TSB on the feature. You could print that off or just make a note of the number. Your dealer "should" be able to bring it up.
Old Jan 5, 2009 | 10:19 PM
Sevir's Avatar
also, these trucks have a high idle feature built into them. if they are at idle for a few mins it will automaticly go to 1000rpm. You might think its the manual high idle feature. If the auto one activated, you cannot change its RPM range.
Old Jan 6, 2009 | 08:15 AM
moterhead's Avatar
It's my understanding that this type high idle only works during cold temps, I think, below 32F. The manually controlled one can be used any time.
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
