03 manual transmission question
Old Jan 5, 2009 | 02:20 PM
DBroadhead's Avatar
what tool and size of tool is used on the fill plug of a 6 spd manual tranny on 03 2500 4x4 also what is used for draining it?
Old Jan 5, 2009 | 02:54 PM
Valv's Avatar
To drain it you have to remove the bottom bolt of any of the 2 PTO covers.
To fill it up you should use the top bolt of the covers or better take shifter off inside cab and fill from there. It's best if you overfill by at least 1 quart.
Old Jan 5, 2009 | 03:42 PM
DBroadhead's Avatar
Thanks
I apprecate your reply but what is the star type plug on the passinger side?
Old Jan 5, 2009 | 05:08 PM
Valv's Avatar
It actually is the fill plug but it's been proven the fill through top PTO hole will help with lubrication and cooling.
Do a search on NV5600 on this site, you'll find about 2 weeks worth of reading. There's a lot of information, opinions, etc about these transmissions.
Old Jan 5, 2009 | 06:50 PM
C Schomer's Avatar
I think it's 17mm allen. I took a 3/4" hex allthread connector and filed one end til it fit. Pull a pto cover and mop out the remaining oil and clean off the magnet that's in the bottom. I drilled and tapped a drain in mine. Craig
Old Jan 5, 2009 | 09:14 PM
radshooter's Avatar
If a person wanted to check the oil level in his NV5600, how would I go about it? Can I check it through the top PTO bolt hole? Will anything drain out if the bolt is removed? I had my tranny oil changed 5000 miles ago, and now it seems to shift a little stiffer than before. Could it be low on oil?
Thanks
Old Jan 6, 2009 | 07:22 AM
MikeyB's Avatar
Can check the level via the large allen plug on the driver side of the tranny. If it's on level ground and the shop used that hole for filling very little fluid should come out.
Use the top PTO hole for adding the extra quart above the stock level.
MikeyB
Old Jan 6, 2009 | 08:20 AM
radshooter's Avatar
Thanks MikeyB. I had forgotten about the allen plug.
fpr01
13
Sep 21, 2008 11:31 AM
imelmo
Oct 9, 2006 06:45 AM
ezdemon72
14
Jul 29, 2005 10:05 AM
IH8MYCAT
26
Mar 4, 2005 03:21 PM
adamroofer25
Aug 24, 2003 02:31 PM
