couple of rear main seal install questions
Old Apr 9, 2010 | 10:20 PM
jay_d's Avatar
Im planning on doing this tommorrow, What am i in for? I know the trans needs to be pulled and that doesnt seem to be a big deal. Can i put this new seal in without pulling the bellhousing?
As far as i know it can be done by just pulling the trans and flex plate off
Old Apr 9, 2010 | 11:28 PM
torquefan's Avatar
You must be referring to the adapter plate on the back of the engine. No, you don't have to remove it. After you get the flex plate off, you can just drill or punch a small hole in the metal body of the seal, then thread a sheet-metal screw in a couple threads and lever it out with a pair of side cutters.
Old Apr 9, 2010 | 11:58 PM
jay_d's Avatar
awesome thanks for clearing that up for me, some ppl say to lube up the seal and crank, some say dont, any idea?
Old Apr 10, 2010 | 08:30 AM
jhenson's Avatar
I'd go ahead and replace the cam seal as well. It's just a o-ring with an inspection cover over it. They are very prone to leak and while it's down that far whats another 2 bucks.
Old Apr 10, 2010 | 08:33 AM
mitternocht's Avatar
I’ve read on here that there is a square o-ring seal between the trans adapter and the back of the engine. I guess it seals around the back of the camshaft or something. Guys say this can leak too.
When I installed my SB I but a new rear main seal in, but didn’t know about the o-ring. I now have a leak back there somewhere. I’m not sure if I got a bad new seal or put it in out of alignment or if that o-ring has let go.
So have a close look around back there. If you take the adapter plate off maybe you can take some pix for us?
Old Apr 10, 2010 | 08:35 AM
That is what people are talking about....anyone have a PN?
Old Apr 10, 2010 | 11:59 AM
torquefan's Avatar
No, I have done many of these (although never a third gen) and the Cummins instructions are very clear about stating that both parts must be clean and dry upon installation. No lubricant is to be added. I am not aware of that changing on the third gen truck.
As far as replacing the camshaft o-ring, I have not had the experience of one leaking so I won't advise either way.
Old Apr 10, 2010 | 09:33 PM
RTillery's Avatar
If you have a framing (claw) hammer with fairly straight hooks, it works great on prying on the head of the screws you put into the seal.
MoparMarv
Feb 22, 2015 07:08 PM
6spd05Dually
May 12, 2011 09:44 PM
gozapper
May 1, 2010 11:02 AM
Billut
Feb 20, 2010 05:44 PM
bnold
Jul 7, 2007 06:18 PM
