Code Question?
Old Mar 1, 2007 | 10:25 PM
mtblackdog's Avatar
Code Question?
Im wondering if anybody can tell me what this code is thanks.
P0336
Old Mar 1, 2007 | 10:27 PM
bekim's Avatar
Not familiar with that one.
Mike
Old Mar 2, 2007 | 02:55 AM
TexasCTD's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Mar 2, 2007 | 07:38 AM
RamWheelsBy4's Avatar
P0336 Generic Crankshaft Position Sensor A Circuit Range/Performance
Common code thrown with TST PowerMaxCR. If you have a TST box then not much to do but clear and ignore it. If you do not have a TST and have the code, does the truck run normal? If so I would not worry about it. Clear it if you can and see if it comes back. If it does check the wiring harness and connector to the crank shaft sensor.
Old Mar 2, 2007 | 08:51 AM
mtblackdog's Avatar
Thanks, seems to be running fine.
Old Mar 2, 2007 | 09:30 AM
FarmerJim's Avatar
Code 0336
If you lug the engine at 1000 to 1200 rpm it can cause this code especially if you have a TST. Just clear it and ignore it. I used to get it quit a bit till I learned to let the rpms build a little more while going thru the gears and I do not get it anymore. I do not know what you could do if you have an auto trans.
Old Mar 2, 2007 | 11:33 PM
Lomarker's Avatar
I've had this code twice lately, both after extended start/crank times. Truck seems to run ok, and code clears after a few cycles. I'm wondering about why I'm getting the code with the long cranks.
Old Mar 3, 2007 | 08:26 AM
FarmerJim's Avatar
Code 0336
I would check the connector at the Crankshaft Position Sensor. Make sure it is making good contact. Might want to put some dialectric grease on the contacts before you put it back together.
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
TEDHRS
Nov 9, 2002 12:35 AM
