Anyone install higher gears?
Old Sep 3, 2004 | 09:25 PM
Kendall's Avatar
I am looking at an 04.5 and was wondering if anyone has swapped out the 3.73s for some 3.55s or 3.21s? A diesel is major overkill for what I plan to do with it. I tow a 8X8X12 enclosed trailer that weighs about 2500 lbs or so loaded. I do most of my driving commuting to work about 40 miles or so round trip. I want longevity, so that was the reason I chose the diesel. I'm a 25-30K per year driver. My current 4.7 quad cab suits me fine other than the fact I only get about 8 MPG pulling my draggy trailer (70+ MPH). Anyway, since I would be towing such a light load, I was wondering if I could squeeze some extra MPG by running a taller gear.
Thanks,
Kendall Ducote
www.lapowerchutes.com
Old Sep 4, 2004 | 03:03 AM
jkitterman's Avatar
Slowing down will help the most. I don't think there are other gears except the 3.73 and 4.11 right now for these axles.
Old Sep 4, 2004 | 08:55 AM
FarmerJim's Avatar
It would probably be cheaper to go for a Gear Vendors or U S Gear overdrive for the truck than changing complete rearends since as was stated at present the only gears available for the American Axle are 3.73 and 4.10.
Old Sep 4, 2004 | 09:58 AM
Several members are running the add-on OD units and are happy with them. They seem to be strong enough with a stock engine but adding more power pushes them too far.
Old Sep 5, 2004 | 11:03 AM
hammerjammer's Avatar
have you thought about taller tires ?? Be a lot less expensive and the same effect.
Old Sep 6, 2004 | 09:59 AM
Kendall's Avatar
I didn't know that there is only 2 gear ratios available for that axle. Tires seem like the only other option. Thanks for the input.
Kendall
Old Sep 6, 2004 | 11:26 AM
BigBlue's Avatar
I'd go with taller tires. A set of 33's will drop the ratio down on the 3.73 to like a 3.6x or 3.5x. And believe me, you don't want anything higher than that. I've got the 3.54 factory ratio and with 33's, my truck was a dog in the city. With the 35's, it's a slug.
Old Sep 6, 2004 | 04:55 PM
bulabula's Avatar
If I was you, I'd buy the truck first; give it a shot with whatever its got in it, then make the business decision on whether or not to do gears.
I don't think you'd want to bother with them after you've driven it a while. You could put that cash to work elsewhere on the truck.
Old Sep 6, 2004 | 05:06 PM
Hounddog's Avatar
Also and it hasn't been brought up but gear swaps are really illegal.Goes against Epa and Cafe fuel mileage.Proberly will never be checked but its as serious in some ways as removing the cat.
Old Sep 6, 2004 | 06:42 PM
bulabula's Avatar
Houndog, is that in GA? It not illegal to do gears here; there's a thriving market around these parts. If it was was, the local ****'s would put the kabash on it in a hearbeat.
Old Sep 6, 2004 | 10:08 PM
BigBlue's Avatar
That's the first I've ever heard about that.
Old Sep 7, 2004 | 12:22 AM
Hounddog's Avatar
Its been that way.Its a one of those things no body knows deal.Like I said I doudt it would ever be inforced.
johnr9q
13
Aug 8, 2009 01:59 PM
black_dog
21
Oct 25, 2007 12:32 PM
93beater
Feb 28, 2007 09:28 AM
jerry007
Oct 28, 2004 08:24 AM
13
Mar 29, 2003 11:46 AM
