#4 injector HP fuel line
Old Mar 22, 2009 | 06:16 PM
shep1's Avatar
Question #4 injector HP fuel line
Just wondering if anyone has had any more problems after having the #4 injector HP fuel line replaced ?
Mine was done at 45K. 56K now and no problems.
Is this a permanent fix?
Old Mar 22, 2009 | 06:27 PM
woodrep's Avatar
What happened to require yours to be replaced?
Old Mar 22, 2009 | 09:12 PM
NickBeek's Avatar
I think mine was replaced at about 40K, now at 93K no problems yet.
Wood the #4 line is prone to cracking and spewing fuel around the engine compartment which unfortunately will leave you needing a tow to the dealer.
Old Mar 22, 2009 | 09:27 PM
woodrep's Avatar
Great!.... Did it just blow out on you guys or are there signs? I had to replace my #6 injector last week and I was inspecting my rail and line fittings to make sure everything was snug, but wasn't looking for cracks.
Old Mar 23, 2009 | 07:53 AM
Mr Bee's Avatar
I replaced #3 last Christmas eve at 135K broke under the ferrell... what a mess
Old Mar 23, 2009 | 06:02 PM
NickBeek's Avatar
Wood, there are no warnings. It just lets go and you have a mess. DO NOT check for leaks by hand with the engine running. The pressure in those lines can badly injure or KILL a person.
Old Mar 23, 2009 | 08:17 PM
woodrep's Avatar
Point taken. Thanks
Old Nov 26, 2009 | 01:58 PM
shep1's Avatar
#4 fuel line
Must be permanent fix as no one has commented on this problem in quit awhile.
Can any one explain how to relieve the high pressure on these fuel lines so they can be replaced without being dangerous??
Old Nov 26, 2009 | 02:09 PM
NickBeek's Avatar
I don't think the pressure stays high after shut down. I am not sure about this, but I know a few people who have done injector swaps / upgrades who have never mentioned a warning about dis-assembly and left over pressure. These people would have mentioned it for sure.
Old Nov 26, 2009 | 04:13 PM
BigDogJeepin's Avatar
The pressure drops to a reasonable level at shutdown. Replacement is as straightforward as it looks. I replaced mine before it broke because there were so many threads here describing the replacement lines like they were a different alloy. That does appear to be the case to me, too.
I carry the OEM as a spare.
Old Nov 29, 2009 | 07:59 AM
Valv's Avatar
Get the part at a Cummins dealer, mine was $ 23.11 with tax, local Dodge dealer wanted $ 68 !!!
Very simple and easy repair, it takes about 10 minutes, 3/4" for the line and 10mm for the clamp down.
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
adidasman23
14
Nov 13, 2006 01:14 PM
BRUISER
Sep 3, 2006 11:04 PM
Tommy93w350
Aug 6, 2004 11:13 PM
