Fuel Return line from Regulator....Vent line?
Old Jan 13, 2008 | 11:51 PM
Tiara3100's Avatar
I will be installing a new holley Gerator pump (150gph at 16PSI) on my truck in the near future. I would like to install a pressure regulator with a return line to the tank. Can I plumb the return line into the vent hose that connects to the filler neck?
Old Jan 13, 2008 | 11:58 PM
shortbed rv's Avatar
http://www.glacierdieselpower.com/im...rf-Install.pdf
Thats ALMOST the way glacier does it. I dont see a problem except that vent line is 3/4 ID. I use that vent line to conect my aux fuel tank.
Old Jan 14, 2008 | 06:53 AM
jrussell's Avatar
16psi is pretty low. I don't think you need a regulator for that pump.
Old Jan 14, 2008 | 10:06 AM
Minwy's Avatar
If that's a gerotor pump its capable of producing alot more than 16psi, use a bypass regulator and not a standard pressure regulator. I plumbed mine in to the return at the engine, I wanted to regulate the pressure after the filters so I knew how much pressure the cp3 was getting at the inlet, not what the filters are seeing. Where you return to tank doesnt make much difference as long as you dont have too much restriction, too much and your regulator wont be able to regulate pressure below what the return lines restriction pressure is.
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
PsRumors
Mar 2, 2006 06:44 AM
