IP return. At what pressure does it vent/return?
Title.
Just wondering at what pressure the injector pump return actually starts to return fuel to the tank.
Like on a second gen truck it's typically between about 25-35psi.
All the time, there is no spring in the overflow valve on a VE pump, there's a small hole that is sized for the particular application, case pressure is over 100 psi and increases with rpm, that's how the variable timing of the pump works.
ahh gotcha. good to hear, and that makes sense. I was kinda thinking that it wouldn't make sense that it would return the same way as a ppump. I wonder what kind of pressure it would go to if it didn't have a return... or if you were able to push enough fuel to actually make it drop a lot to have a shut off thing on there if the pressure dropped below a certain PSI.
97catintenn
Aug 7, 2009 08:23 PM
Tiara3100
Jan 14, 2008 10:06 AM
cLAYH
Apr 21, 2006 08:16 PM
PsRumors
Mar 2, 2006 06:44 AM
