04.5 HO 3500 auto, thermostat almost just below 200 on gauge cluster too hot?
i was just driving my truck and looked down and the temp gauge is reading 190-195 i would say.
is this correct about right?
i have another truck with the dodge 360 gasser engine, and it shows around 170.
i thought this was a diesel , and diesel runs cooler
its also 35-40 degree's out right now fairly bitter and windy...
it was dark when i got home but ill check coolant in the morning..
also the temp gauge sorta jumped it was at 165 or so for a while, then i looked down and it had jumped to the 190 area....
only 7000 miles on the truck, i doubt its anything, im probably just being stupid :/
thanks for info.
thanks for info.
thanks, just wondering about the average temp, i thought it was weird that my 99 3500 with box on it at load holds at 170-175.
is this because of the turbo on the engine? creating more heat?
The theromstat is set at that temp. If you want it cooler...get a lower temp thermostat. It is that simple. Cummins decided that 190-200 degrees was the ideal operating temp for this motor, so they installed a thermostat likewise.
Mine's funky. During the summer it sits right at 185 not matter what. Now that it's colder outside, it bounces between 210-185. It's never done that before. I think it's time for a new t-stat and coolant. It's only got 73K miles on the original stuff.
From: New York City / Terre Haute, IN / San Antonio, TX
If your cooling system is working properly (and considering the fact that the radiator our trucks come with is larger than some engines, it's hard to believe it wouldn't be), your engine will run at the temperature set by the thermostat. Your 360 gasser motor must have a 170 degree thermostat in it. I believe our trucks have a 190 or 195 degree t-stat in them. My truck is kinda funky. When I start it up and get on the highway, it will go up to 205 and then drop back down to 190-195. Around town (when I'm actually driving around town long enough for it to get up to temperature) it'll run about 5-10 degrees cooler.
Your truck is fine. Newer cars run hotter temperatures to improve combustion efficiency, run leaner mixtures, and hence improve emissions. The colder your engine runs (to a point) the more power you'll make. Cummins chose the thermostat it did as a compromise of engine emissions and power.
MossyOakCTD
19
Dec 28, 2010 09:11 PM
Bookshelf
May 30, 2009 01:17 AM
desertrefugee
Jun 6, 2007 10:49 PM
duallydave
Aug 7, 2005 09:38 PM
