04.5 high idle???
Old Nov 26, 2004 | 08:08 PM
wexman's Avatar
The technician came out and when I explained what I wanted he said he had never heard of this.
Shouldn't this be STANDARD training and knowledge with technicians? Why is this such "top secret" info among technicians?
I just don't get it?
Old Nov 26, 2004 | 08:30 PM
Rod_Montana's Avatar
My point in mentioning this was to help others not be discouraged if the dealer seems to lack knowledge. The feature is there, and the customer can often help train the dealer.
This technician did make the comment that because of the internet, customers seem to get the new info faster than the guys who spend all day under the hood. Speciallized training comes periodically, but sometimes months pass between updates.
That said, If I was a CTD technician, I'd be spending time every night here. (heck, I do anyway.)
Old Nov 27, 2004 | 12:04 AM
ed paul's Avatar
so, what do we need a high idle for?
Old Nov 27, 2004 | 07:14 AM
Blue600's Avatar
Prevents wetstacking, faster warm up, warmer engine in the winter and better A/C sitting in parking lots.
Old Nov 28, 2004 | 04:25 PM
moterhead's Avatar
"Wetstacking"????
Old Nov 28, 2004 | 06:17 PM
Blue600's Avatar
Originally posted by moterhead
"Wetstacking"????
Yes. Cylinder washdown with fuel, unburnt fuel collecting on valves preventing them from closing.
Old Nov 28, 2004 | 07:37 PM
PapaPerk's Avatar
So the high idle is only available for Auto trans? Why no manual????? I really would like the high idle feature when I have to idle for extended amounts of time. Any suggestions?????
Old Nov 28, 2004 | 08:20 PM
Bubba_CTD's Avatar
From: From Texas; Staioned in WA; Transplanted to AZ
I have the High-Idle on my 600, but a buddy of mine has an 03 555 and was wanting to know if it can be enabled on his truck as well.
Wait a minute... I recall his being the 6-spd, so it couldn't be enabled anyhow even if it was a 600 could it?
Old Nov 28, 2004 | 09:59 PM
moterhead's Avatar
It can't be enabled both because it's a six speed AND because it's an '03. There was a major change from '03 to'04 in the engine control systems. '03 has both an ECM and PCM. '04 has only a ECM. '03 is DC software. '04 is Cummins. (I think this is right!). If not someone with a better memory will correct me.
The '04 555 must have the 004-04 TSB reflash done, then the high idle feature enabled. The '04.5 and '05 600s already have the feature. It just must be enabled by a dealer tech. Again, it's only applicable to automatic transmissions. Why? Ask DC.
The high idle feature being discussed is the one controlled by the cruise control, not the low temp one.
Old Nov 28, 2004 | 10:53 PM
J BODY's Avatar
You don't get it? "IT" is that you have an interactive community with groups of people that share knowledge on your particular vehicle. All the way from techs, aftermarket specialists, vendors, etc... Techs on the other hand have to keep up on so many model years and changes and different vehicle lines it's impossible to keep up on the updates. There's guys in my shop that have no clue about the high idle enable, but they don't work on the diesel truck. I live in the desert. High idle isn't much of a concern out here, but through this board, I was familiar with it enough to know when the first guy came through the door inquiring about it. Knowledge is king no matter how it is gained.
Old Nov 29, 2004 | 11:10 AM
Bubba_CTD's Avatar
Cool Wayne, thanks for the info... I wasn't sure if the earlier models could have it done and like I said, it wasn't until after I started typing that I remembered he had the 6-spd.
Bryan
Old Nov 29, 2004 | 12:19 PM
RAMV's Avatar
Darn -- so this is not available at all for 6 spds? I'm jealous... My buddy's '05 6.0 Ford has a single setting one already there, just needs a switched trigger current.
Old Nov 29, 2004 | 02:17 PM
bigblock2stroke's Avatar
All ECM's have the algorithm for the high idle feature. Its original intent was for PTO operation but was shot down for whatever reason.
In the auto's its approved due to the park/nuetral switch being available as a safety. There is no switch in the manual trucks, so the high idle is not approved. Basically, it would be possible to engage 1st gear and do a launch at 1500rpm (until the ECM sensed vehicle speed>0 and would automatically shut the high idle feature off). I know they were working on a switch that you would get from Mopar but I haven't heard if it was released yet.
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
