04.5 Cummins hard knock and smoke throwing codes
Old Feb 11, 2017 | 06:09 PM
Dean Parks's Avatar
Got a 04.5 cummins and was driving it home when all of a sudden it started a hard hard knock (extremely loud). Immediately shut it off and towed it home. Anyways it's smoking white bad and knocking. Got codes p0201 p0202 p0203 p0204 p0205 p0206. I took valve cover off and unhooked each injector and started truck each time and knock never went away. Unplugged the fca and it didn't change anything. I dont know why to do next??? HELP!!
Old Feb 11, 2017 | 08:54 PM
deere country's Avatar
Did you check oil level in it? Check your intake plumbing for oil from a blown turbo seal? If it's a hard knock it's quite possibly a rod bearing failure or main bearing too.
Old Feb 11, 2017 | 09:54 PM
Dean Parks's Avatar
oil is good. But why would I be getting a code from all 6 injectors if it's a bearing?
Old Feb 11, 2017 | 09:57 PM
Dean Parks's Avatar
i forgot to mention the codes I posted are "injector circuit open" got the same code on each injector
Old Feb 11, 2017 | 11:22 PM
I suspect the codes are from when you unhooked each injector. Can you check oil pressure with a mechanical gauge?
Old Feb 12, 2017 | 07:34 AM
Dean Parks's Avatar
ive cleared all the codes and they came back and yes oil pressure is good
Old Feb 12, 2017 | 09:17 AM
Mexstan's Avatar
Remove the oil filter and open it up. Check for metal particles. If no metal, there is a good chance that the knock is not bearing related. Any metal that shows up in the filter is unfortunately $$$$.
Check the water level? Don't think this is the problem, but maybe a blown head gasket?
Keep us posted on what you find.
Old Feb 12, 2017 | 10:59 AM
So you checked it with a mechanical gauge or your making an assumption based on the instrument panel? What was the mechanical gauge reading?
Old Feb 25, 2017 | 07:18 AM
Have you found the cause of the knock in your engine?
RAMdriver67
Mar 18, 2012 09:22 PM
Zee
Mar 23, 2010 09:54 PM
dodgecbr600rr
Feb 10, 2008 07:55 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
