Front Pads and Rotors
Old Jul 14, 2008 | 08:43 AM
Underpsi's Avatar
For a 96 3500 2wd. All the places I called needed the GVW and whether it has rear abs or 4 wheel abs. The truck has a 10500kg GVW and just rear abs the pads are regular price like $48 but the rotors are with the hubs and cost $260 a piece. Is it possible to change just the rotor and not the hub as well? Is there a cheaper way to replace the rotors? I've never had the front end of these trucks apart so I don't know how they are
Old Jul 14, 2008 | 09:14 AM
12valve08's Avatar
Should be able to beat the wheel studs out and get the rotors off.... but dnt damage the studs
Old Jul 14, 2008 | 09:16 AM
12valve08's Avatar
U have to remove the hub before u do anything
Old Jul 14, 2008 | 09:18 AM
infidel's Avatar
2wd rotors are much more expensive than 4wd because the bearings aren't removable.
But at least 2wd bearings can be repacked and last longer than the "lubed for life" 4wd hubs.
Old Jul 14, 2008 | 09:37 AM
Underpsi's Avatar
so I should just buy the rotors for $260? what pads should I use on them, middle line?
Old Jul 14, 2008 | 12:22 PM
seahawkdodge's Avatar
It depends on your uses. If you tow, get the HD pads. If not, run premium or SUV/Truck pads.
Old Jul 14, 2008 | 12:35 PM
supersportjim's Avatar
i just replaced my rotors and worn out hub. $600 for both hubs and $100 for both rotors and $50 for pads ouch.. 98, 4wd, 3500, 4wheel abs
Old Jul 14, 2008 | 04:10 PM
Dave Miller's Avatar
Rotors and pads for me. $135 apiece for NAPA drilled/slotted rotors and $70 for HD pads....97 4wd 3500 rear ABS. I know the hubs are expensive....and some day they are next...ouueouch.
Old Jul 14, 2008 | 04:53 PM
yeah i go to advance auto parts i have a commercial account there..
Old Jul 14, 2008 | 08:06 PM
DodgeRamdiese01's Avatar
about how long do these rotors and pads last? the reason I ask is because I buy the cheaper stuff and get about a year and a half out of the pads
Old Jul 14, 2008 | 08:46 PM
mahdey's Avatar
rock auto.com 51 bucks a rotor.
Old Jul 15, 2008 | 09:44 AM
infidel's Avatar
Good quality rotors will last a long time as long as you don't let the pads wear down to metal.
My stock rotors barely made it to 50k, their Brembo replacements have close to 200k and look brand new.
I usually get about 50-75k out of a set of Hawk pads.
Jkerr40
May 1, 2014 09:11 AM
plessm
Apr 27, 2014 12:55 PM
deanhinsley1963
Aug 2, 2010 07:45 PM
Mcmopar
May 11, 2004 09:46 PM
Scubasteve
Sep 3, 2003 08:19 PM
