Cruse control
Old Jan 14, 2010 | 09:04 AM
maroonbeast06's Avatar
Cruse control
my cruise control works when it wants to when you turn it on and hit the set button it doesnt set but if you hit the accel button over and over till the cruise wakes up then it sets and hold but then i have to back the mph down or i will be doing well over 70 if anybody has any suggestions please help i am driving from california to corpus christi texas in two weeks
2001 dodge ext cab short bed 4x4 CTD 47re<(POS) fass 150, quadzilla adrenline, power puck, hrvp44, ball bearing turbo,4inch turbo back 5in tip all home made exhaust gotta love galvanized 4inch stop signs! I call her the maroon beast
Old Jan 14, 2010 | 11:44 AM
Fueling around's Avatar
A few places to check.
Clockspring in steering wheel
Connection to cruise module under driver side battery. Also the cruise module and vacuum lines are often damaged from battery juice.
Welcome to DTR
Old Jan 14, 2010 | 01:59 PM
thank you i will check into that also would having oversize tires effect this in any way
Old Jan 14, 2010 | 02:18 PM
VICIOUS FISHER's Avatar
No, oversize tires are not an issue.
fueling around offers good advice, however when my clockspring went on my 98 I also got an airbag light
Old Jan 14, 2010 | 05:54 PM
that light hasnt come on i mean at 162000 miles i gues stuff just gets old how hard is it to fix this problem and will it be a huge ordeal to fix or do i need to take it into the shop?
Old Jan 14, 2010 | 09:31 PM
West Coast's Avatar
Switch contacts can get dirty also. Used compressed air and blow around the switches....
Old Jan 14, 2010 | 10:23 PM
98DRQC12V's Avatar
Seems like I've a similar problem for years now. In cold weather only (all is fine during summer months) the cruise sets on target, but then increases speed to well above the speed limit (actually been ticketed once because of this). The only way I can beat it now is to set it well below the speed limit then drive at higher speeds for 5 to 10 minutes after which I can reset the cruise to the desired speed. To date, I haven't found a solution to this. Also, about 2 weeks ago the CRUISE idiot light on the dash no longer lights, but the cruise continues to work in the manner described. Perhaps someone may have some hints/fixes about this behaviour.
Old Jan 15, 2010 | 10:26 AM
i would take that problem anyday mine just wont grab and hold
oldblues
Aug 4, 2007 11:17 PM
Evertight
Feb 19, 2007 11:57 PM
alborada
Jul 22, 2006 12:20 AM
xyzer
Apr 23, 2005 01:06 AM
