Cruise control problem
Old Jan 14, 2010 | 09:10 AM
maroonbeast06's Avatar
I am having a problem with my cruise control. when you turn it on and go to set it it wont set at the selected speed but if you hit the accel button over and over it will eventually grab and hold but then you have to hit coast or it will take off like a R**** Ape this has been going on for a little while any help is greatly appreciated
2001 CTD ext cab short bed 4x4 47re<(POS) HRVP44 Fass150 4inch turbo back with 5in tip K&N air filter ball bearing turbo quadzilla adrenaline and for laughs a diablo power puck i call her the maroon beast
Old Jan 14, 2010 | 12:48 PM
SIXSLUG's Avatar
Clockspring. search it.
Kurt
Old Jan 14, 2010 | 01:57 PM
were would that be located at if u dont mind me asking i have done all of my own repairs just dont know about all this little electronic c***
Old Jan 15, 2010 | 01:05 AM
SIXSLUG's Avatar
Its in the steering column behind the steering wheel. You have to remove the wheel to get at it. Watch out for the airbag, this needs to be disconnected in order to replace the clockspring.
Kurt
Old Jan 15, 2010 | 09:43 AM
mpfireman's Avatar
On my 98.5 the cruse control just quit working one day. What I found was a hole in the small plastic tube, under the battery box, drivers side. Spliced in a new piece, FREE, and it is now working trouble free.
Could your problem be loosing the vacuem to the sending unit?
Old Jan 15, 2010 | 10:24 AM
im guna take and pull my battery box this weekend and go get some new hose and just redo all the vaccum lines also about 3 weeks ago i noticed that under the hood on the passenger side the vaccum hose that runs out of the fire wall above the a/c unit had come apart so i left it then got in the cab and my a/c selector switch was dead so i jerry rigged that piece and now it started working. but also my other question would be were could you get vaccum hose that small ?
Old Jan 15, 2010 | 10:52 AM
mpfireman's Avatar
I did not replace the good parts of this small plastic tubeing, but the auto parts store had a larger size that this OEM hose would just fit into. Worked reall well. Dodge wanted like 21 dollars for the replacement hose. Or you can search out junk yards.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
TexasDiesel
Dec 27, 2002 10:47 AM
