Cruse Control Surge
Old Apr 20, 2005 | 09:24 AM
xyzer's Avatar
Cruse Control Surge
Anybody out there ever had a cruse control surge? Mine seems to be to sensitive. It surges and is always looking for the correct speed. It got even more pronounced when I put a box on it! Any help will be appricated!
Old Apr 20, 2005 | 09:47 AM
HOUTEX's Avatar
Problem Solved.......
Old Apr 21, 2005 | 04:34 AM
Dodgezilla's Avatar
I never had it until the dealer did a reflash to fix my tranny. Well, it didn't fix the tranny but now I get the surge between 45-55mph but if I go faster it goes away. Of course, they tell me it's normal even though it never happened before! It does keep the truck at the set speed though, it just doesn't do it smoothly......
Old Apr 21, 2005 | 06:42 AM
pcburnout's Avatar
Mine does too never did with just chip but when injectors where installed it does it now. I think engine being very quick it gets to adjusted speed faster. up-down-up-down. its to not bad though.
Old Apr 21, 2005 | 08:03 AM
xyzer's Avatar
At least I'm not the only one with this little gremlin! Now if we can find the problem. I see there is a saftey reflash for the cruise control (C02) not sure if it is connected.I'm going to check the cable and see if it is sticking. Yell if you have any ideas!
Old Apr 21, 2005 | 08:25 AM
miketriton's Avatar
My truck was smooth at 70 mph until I installed a box. I assume the throttle position is adjusted by the cruise control. It seems that the more powerful the engine (add a box) the same amount of throttle adjustment makes the truck speed up significantly more. After that point the cruise control never levels out.
The answer is to switch off the box while using a cruise control or make the throttle less sensitive at low end throttle adjustments.
Old Apr 21, 2005 | 11:19 AM
Dodgezilla's Avatar
Mine does it without the box too. That's the first thing I checked.....
Old Apr 21, 2005 | 11:43 AM
HOUTEX's Avatar
Problem Solved...........
Old Apr 21, 2005 | 09:31 PM
ZS's Avatar
ZS
Not much to add other than to say I use cruise daily and have NEVER experienced anything like this...
ZS
Old Apr 21, 2005 | 11:29 PM
xyzer's Avatar
ZS
YOUR LUCKY! Mine had a slight surge when new. It was barley noticable at freeway speeds. The slower the set speed the worse it was. I put a box in it and it amplified the problem! I love the extra ponies but I am addicted to the cruse control. It bugs you a bit with the surging or searching it does. It is a bit to sensitive! It appears there are a few people out there with this little gremlin in just the "03's" I'm hoping we can find the fix for it!
Old Apr 22, 2005 | 01:20 AM
HOUTEX's Avatar
Problem Solved............
Old Apr 22, 2005 | 08:10 PM
jnck's Avatar
Mine too has the "surge". I can watch the boost gauge move up and down.
Took it to dealer and they replaced servo unit. No help.
By the way does anyone know of a good dealer in east central Iowa.
I bought the truck used from a non dodge dealer and the local guys are treating me like a dung beetle that crawled into their soup.
P.S. I found out their service and parts dept are not open on the weekends.
Old Apr 23, 2005 | 01:06 AM
blownaway's Avatar
I have the same surge, way worse with the boxes.
frank compagnon
Jun 25, 2011 07:03 AM
oldblues
Aug 4, 2007 11:17 PM
Evertight
Feb 19, 2007 11:57 PM
alborada
Jul 22, 2006 12:20 AM
