BHAF
Old Mar 9, 2003 | 03:13 PM
  #106
Shovelhead's Avatar
Administrator / Scooter Bum
Re:BHAF
The Scotty 3 is for the 2003 Cummins trucks.
Old Mar 9, 2003 | 04:09 PM
  #107
ARAcummins's Avatar
Re:BHAF
Here is my heat sheild I just made this morning, took all of five minutes. I used some flashing because it is 1) easy to work with, 2) readily avaible, 3) looks good, 4) easy to work with. I don't know if it well work because it is flimsy, and I don't have my truck it is in the shop. But I well give it a shot and see how it works, if it don't oh well I well just make another one. My flashing was just a bit narrow, but I think it well work!
Old Mar 9, 2003 | 04:25 PM
  #108
DPG's Avatar
DPG
Re:BHAF
If I recall correctly, you are supposed to use at least 18 gauge galvanized or stainless. I used galvanized for mine, and it seems to work well as far as I can tell.
Old Mar 10, 2003 | 11:54 AM
  #109
BradN's Avatar
Re:BHAF
I installed my BHAF this weekend also. <br><br>I haven't installed the heat shield yet and I am thinking about cutting the hole in the cowl also. I want to make sure that I cut it according to Scotty's directions so when I upgrade , I won't have holes all over the place.<br><br>The turbo whine is more noticeable in the cab and there seemed to be a little more throttle response ;D. However, I am not sure how much of the throttle response is a result of the BHAF because I also changed the oil and fuel filters at the same time. I don't have gauges yet so I can't tell if it dropped the EGT's.<br><br>I will be leaving this weekend for a trip to Missouri and Arkansas so I will see if it helped with fuel economy. With the price of Diesel right now, I'll take anything!!!<br><br>Another question that came to mind while I was doing this is what is the interval for changing the BHAF? I would assume it would last longer than the stock one but how much longer? I was going to do the 4&quot; to 3&quot; PVC reducer so I could in stall the Filter Minder, but my Filter Minder isn't working anyway. :<br><br>FWIW, there is alot of good information in this thread that would make a great FAQ .
Old Mar 10, 2003 | 12:27 PM
  #110
Marine's Avatar
Veteran: Marine Corp
Re:BHAF
I had my BHAF on for 30,000 miles and it still looked good on the inside. I probably could have gone further, but what the hay. When I changed it to the new one, my mileage didn't increase either.<br><br>Mike
Old Nov 6, 2007 | 02:01 AM
  #111
rolling18's Avatar
Originally Posted by dan239
OK Fellas;<br><br>What is BHAF? ???<br><br>Dan
all i know is its a Big?AirFilter
do we have a part number/ vedndor for a 96??
Old Nov 6, 2007 | 09:18 AM
  #112
Dr. Evil's Avatar
Big Honkin Air Filter
NAPA 2790 is the usual one - but you can cross reference that p/n to a number of filter manufacturers.
These guys are pretty cheap: www.fleetfilter.com
Old Nov 6, 2007 | 11:55 AM
  #113
BigB82789's Avatar
Old Thread!
Old Nov 6, 2007 | 06:24 PM
  #114
phox_mulder's Avatar
Originally Posted by BigB82789
Old Thread!
Wow, 4 and 1/2 years old.
I didn't know the database went back that far.
phox
Feb 22, 2024 07:16 AM
Rickcher
Sep 2, 2009 05:08 PM
Ace
Oct 31, 2007 06:46 PM
95ramtough
Mar 30, 2003 09:28 AM
