BHAF or K&N Dropin??????????
Old Mar 19, 2003 | 08:59 PM
95ramtough's Avatar
I will be making a trip to the cummins dealer tomorrow to purchase my fleetgaurd oil/fuel filters, and I also need to change my air filter. Should I buy a K&N? or Should I try to add a BHAF? if BHAF, what all do I need? what are the part numbers?
Old Mar 19, 2003 | 09:10 PM
mymaur's Avatar
Re:BHAF or K&N Dropin??????????
I use a K&amp;N, Cost about $60 at Auto ZOne. I'm happy, got nearly 2 MPG more with it. But others will prefer the BHAF. I have no idea what they cost.<br><br>Part number for the K&amp;N is easily fond in their catalog at the store.<br><br>Gary
Old Mar 19, 2003 | 10:08 PM
nivram's Avatar
hello all first time on this site. got my BHAF at napa #2790 list for about $54.00 i believe. but make a good imprestion, and ask for a discount, if possable. it lowered my egt's by about 100* also a little better spool up. also the 4&quot; exahust lowered the temps also. cummins also carries a BHAf. check it out while there.<br><br>Niv.
Old Mar 20, 2003 | 12:50 PM
KC's Avatar
KC
The BHAF is a bad looking filter as it sits in your engine compartment<br><br>KC
Old Mar 20, 2003 | 01:04 PM
DieselDaze's Avatar
[quote author=98ramtough link=board=5;threadid=12500;start=0#118220 date=1048129182]<br>I will be making a trip to the cummins dealer tomorrow to purchase my fleetgaurd oil/fuel filters, and I also need to change my air filter. Should I buy a K&amp;N? or Should I try to add a BHAF? if BHAF, what all do I need? what are the part numbers?<br>[/quote]<br><br>It is a choice of personal preference. Some like the K&amp;N's, some like BHAF's, and others chose complete systems such as the Scotty II or others.<br>If you go BHAF, you should install a heat sheild. The template can be found Here<br>And the part numbers can be found <br>Here<br><br>If you go wet filter (K&amp;N) you must be sure that the filter is not over oiled. I found that the one I bought was over oiled from the factory. I spent an entire Sunday afternoon/evening cleaning out the filter oil out of my turbo. <br><br>Either way, it is better than stock air flow. <br><br>Rich.
Old Mar 20, 2003 | 02:00 PM
nivram's Avatar
your right, it is the choice of the owner, i tried the K&amp;N, and also done some mods on the air box to lower the egt temps to get more air. and found by going to the BHAF, (i fashioned my own shield) that i was able to run a bit cooler. i was just looking for all the advantages that i could. it works for me.<br><br>Marv.
Old Mar 20, 2003 | 02:34 PM
95ramtough's Avatar
I went ahead and bought a K&amp;N today and put it in. I was careful to not put too much grease around the sealing edges, and the filter did not look like it had been overly oiled. The filter cost $67.99. I chose the K&amp;N filter because I think with all the dirtroad/offroad driving I do it will be better in the stock case. I can't notice much difference, but the turbo is a little louder (with silencer ring off). Hopefully I will not find any oil on my turbo... :
Old Mar 24, 2003 | 01:38 PM
dieselgeek's Avatar
K&amp;N is probably not a good choice for offroading &amp; dust. After a few thousand miles check the intake behind the filter - you might see dirty oil (if over oiled). If not oiled enough, though, the particulate matter might be getting sucked into your engine. <br><br>Every now &amp; again I get on here and remind people my K&amp;N story... my former roommate in college now works for BFG Aerospace in Minneapolis. His company was contracted to do &quot;media testing&quot; for Donaldson filters - the K&amp;N media was includeed in the test. He said that K&amp;N was really bad when new, but a lot better (at filtration) once it &quot;loaded up.&quot; He confirmed it flowed more air for a given vacuum - but that's because it let larger particles through... Anyways, he knew I ran K&amp;Ns for a long time on my cars, so he quickly advised me and I stopped using them. I keep begging him to give me some data that I can post it - but he's too ****, the data is proprietary, etc. He pointed out that there are a number of filter media manufacturers that make filters that flow higher CFM than we'd ever need (ok, most of us would never need) with more effective media than ANY automotive applications.<br><br>Is anyone looking at filtration media made for construction eqiupment? Are all those oil-bath, cartridge style ones? I'm not a filtration expert... but I know I need something soon (just did fiorst upgrade, DD3s) because my own intake is insufficient now...
Old Mar 24, 2003 | 06:04 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I used a K&amp;N drop in for 2 years (on-road only) with no troubles. <br><br>Just switched to the Scotty II. ;D
Old Mar 25, 2003 | 08:17 PM
Racer57's Avatar
As you have already switched to the K&amp;N, good luck with it. I switched from an AFE drop-in, which I ran for 18 months, to a Scotty 2 and given my mods, may be one of my wiser choices in some not-so-wise choices. Excellent reduction in EGT's.
Old Mar 30, 2003 | 09:28 AM
barracuda's Avatar
i popped a k&amp;n in about a month ago, it seemed to improve throttle response from a dead stop a bit or maybe i'm just fooling myself to justify an $80.00 air filter..just my 2 cents..seems to be a love or hate thing w/ the k&amp;n..some say it allows too many particles past..
Rickcher
Sep 2, 2009 05:08 PM
Ace
Oct 31, 2007 06:46 PM
Mark Hodowanec
Feb 26, 2006 08:35 PM
