BHAF comparison: AH19037 & AH19004 "Marine"
Old Mar 20, 2003 | 12:20 PM
ACJC's Avatar
Re:BHAF comparison: AH19037 & AH19004 "Marine"
Very interesting report. To date, I am on my second BHAF and so far had not had a failure of the filter media. It does get a bit moist in the south so I will be keeping a closer eye on the inside of the filter. <br><br>Jim
Old Mar 20, 2003 | 12:27 PM
DEZLPWR's Avatar
Excellent info, Gear Poet! I think next time I will spend the extra $$$ and go for the 19004.... ;D
Old Mar 20, 2003 | 04:31 PM
phox_mulder's Avatar
If you put a prefilter on it, such as Outerwears, it should last a couple of years at least.<br><br>Not a bad alternative for us that want to stay away from oiled filters.<br><br>I had plans to get a BHAF all along, now I will go with the Marine version.<br><br>phox
Old Sep 8, 2003 | 03:45 PM
roperdog's Avatar
TRUTH IN FILTRATION?
http://www.turbodieselregister.com/f...threadid=81015
Old Sep 8, 2003 | 05:44 PM
This thread is an oldie.
When I bought my BHAF I had every intention of getting the Marine version, but the Cummins distributor where I got it was out of the Marine, and I took their last regular BHAF.
I did get the Outerwears Prefilter.
When my current BHAF gets near it's replacement date I'll try again to get the Marine version.
phox
Old Sep 8, 2003 | 11:57 PM
roperdog's Avatar
INCANUS
thanks for your info - this day and age, people will either tell you anything to get to buy something or they won't tell you anything and expect some people to take a bite on that empty hook. if the marine filter flows around 900, i would buy it.
i can't understand why some manufacture doesn't make an intake that: 1) FILTERS per OEM spec (~99%) 2) has virtually unrestrictive flow - upwards towards 1k CFM, and 3) takes a &quot;cold&quot; air suction from outside the engine compartment.
i must be dreaming
Old Oct 1, 2004 | 05:08 PM
HOHN's Avatar
They do make one. It's called the Farr Ecolite and flows 1500cfm...
Old Oct 2, 2004 | 11:51 AM
diesel_kid's Avatar
How much CFM do our engines needs for certain hp levels and/or boost levels? I got a 19004 waiting for me at the Cummins dealer I am putting in my truck and I am looking to get up around the 400 hp mark. Is there some info out there that could tell me how much air I need?
Old Oct 4, 2004 | 11:43 AM
HOHN's Avatar
You can calculate CFM based on displacement *rpm/3456.
Unfortunately, this doesn't account for boost. If you assume standard atmospheric pressure of 14.7 psi, then 29.4psi on your gauge means you have about THREE times more air going into the engine. Remember, your guage reads zero at 14.7PSIA, so you have to account for that when converting from psig to psia.
Though this isn't a linear relationship, it will get you close.
So, with no boost, you'd have about (2700rpm*359cid/3456)= about 280CFM.
But with 29.4psi, you're looking at about 840CFM!!
It's not exact, because turbo efficiency determines how much air actually moves for a given amount of boost, but it's close enough for planning purposes.
Justin
Old Oct 4, 2004 | 12:24 PM
AggiePhil's Avatar
This sounds like a very expensive option, whereas the regular BHAF is pretty economical. Why don't y'all just save up for a ScottyII or something?
Old Feb 22, 2024 | 07:16 AM
Marine's Avatar
Veteran: Marine Corp
I'm going to hop in on this old thread.
I spoke with FleetGuard prior to this post (IIRC) and if you search I think I added this info into this forum. They said that the AH19004 (Marine version) has the same flow capacity as the AH19037 at 918 CFM. The difference is the internal cage in the Marine version. They did not say anything about the media being any different.
Thanks!
ckennedy
Apr 11, 2006 02:39 PM
Mechanos
25
Oct 21, 2004 02:50 PM
Mechanos
Jul 1, 2004 10:29 AM
fitzer
Jun 4, 2004 08:53 AM
phox_mulder
May 7, 2003 06:48 PM
